ConferenceClient throws NullPointException during conference, is there something wrong?
@Override
public void onError(final String id, final String errorMsg, boolean ignored) {
OwtError error = new OwtError(3000, errorMsg);
callbackExecutor.execute(() -> {
if (pubCallbacks.containsKey(id)) {
triggerCallback(pubCallbacks.get(id), error);
pubCallbacks.remove(id);
if (subCallbacks.containsKey(id)) {
triggerCallback(subCallbacks.get(id), error);
subCallbacks.remove(id);
for (ConferencePeerConnectionChannel pcChannel : pcChannels.values()) {
if (pcChannel.key.equals(id)) {
if (pcChannel.publication != null) {
pcChannel.publication.onError(error);
} else {
pcChannel.subscription.onError(error); //here throws NullPointExceeption???
onEnded(id);
Error log:
owt.conference.ConferenceClient.onError(ConferenceClient.java:897)
owt.conference.ConferencePeerConnectionChannel.lambda$onSetFailure$1(ConferencePeerConnectionChannel.java:118)
owt.conference.-$$Lambda$ConferencePeerConnectionChannel$4ynIeN9NpcOnciZS8-G4eTd1v60.run(lambda)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
java.lang.Thread.run(Thread.java:818)
- Tags:
- HTML5
- JavaScript*
Another error log for this exception.
owt.conference.ConferencePeerConnectionChannel.lambda$onIceConnectionChange$3(ConferencePeerConnectionChannel.java:134)
owt.conference.-$$Lambda$ConferencePeerConnectionChannel$QoR_dXe_OM-yy_01bz8PWHj3SOQ.run(Unknown Source:4)
java.util.concurrent.ThreadPoolExecutor.processTask(ThreadPoolExecutor.java:1187)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
java.lang.Thread.run(Thread.java:784)
Another error log for this exception, I think the bug would be similar. The pcChannels has removed the key, but the callback execute for the key as before.
1 owt.base.CheckCondition.RCHECK(CheckCondition.java:42)
2 owt.base.CheckCondition.DCHECK(CheckCondition.java:33)
3 owt.conference.ConferenceClient.getPeerConnection(ConferenceClient.java:505)
4 owt.conference.ConferenceClient.onProgressMessage(ConferenceClient.java:639)
5 owt.conference.SignalingChannel.lambda$null$7(SignalingChannel.java:113)
6 owt.conference.-$$Lambda$SignalingChannel$vEze82r4HvjvcbCPecLEzAzAn_s.run(Unknown Source:4)
