Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
ios SDK 3.3 scale remote stream to fit whole screen without skewing
Zhen_L_
I am trying to show a remote stream from a desktop camera.
The desktop camera has a resolution of 640 width and 480 height.
And I would like to show this stream into a full screen portrait phone...
Currently, the stream show up but it is skewed. I believe it is doing UIViewContentModeScaleToFill
So it scales the frame image and fit it in.
But when I change the content mode of remoteview (RTCEAGLVideoView *remoteVideoView)
 into UIViewContentModeScaleAspectFill
it is still doing the same thing.
Do you guys know if it is a bug in my code? Or is this a known issue in the ios Webrtc library? Below is the layoutSubviews method in my streamView.m file
-(void)layoutSubviews{
    screenSize =  [UIScreen mainScreen].bounds;
    //mask localVideo
    CALayer* maskLayer = [CALayer layer];
    maskLayer.frame = CGRectMake(0,0,localVideoWidth ,localVideoWidth);
    maskLayer.contents = (__bridge id)[[UIImage imageNamed:@"local_camera_mask"] CGImage];
    _localVideoView.layer.mask = maskLayer;
    // remoteVideo
    CGRect remoteVideoViewFrame=CGRectZero;
    remoteVideoViewFrame.origin.x = 0;
    remoteVideoViewFrame.origin.y = 0;
    remoteVideoViewFrame.size.width = screenSize.size.width;
    remoteVideoViewFrame.size.height = screenSize.size.height;
    _remoteVideoView.frame=remoteVideoViewFrame;
    _remoteVideoView.contentMode=UIViewContentModeScaleAspectFill; // <-- Change contentModel here
    [_remoteVideoView setSize:CGSizeMake(remoteVideoViewFrame.size.width, remoteVideoViewFrame.size.height)];
Jianjun_Z_Intel
Hi Zhen,
It looks like contentMode does not work at this time. You can customize the way how video renders by creating a new view implements RTCVideoRenderer.
Somnus_Chen
Jianjun Z. (Intel) wrote:
Hi Zhen,
How to customsize the way? Could you provide a simple? Thanks a lot!
