Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
"Error: node not found" when running bin/init.sh
Stephen_-_
Hello, I am trying to install the v2.8 MCU server on ubuntu 14.04 inside of virtualbox.
I got up to the point of bin/init.sh --deps and things were going okay until this:
rabbitmq-server is already the newest version.
mongodb is already the newest version.
The following packages were automatically installed and are no longer required:
  ax25-node libax25 openbsd-inetd
Use 'apt-get autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 46 not to upgrade.
Initializing mongodb...
MongoDB already running
Initializing default configuration...
Error: node not found. Please install node v0.10 first.
sed: can't read /home/s/Downloads/Release-v2.8/etc/woogeen_config.js: No such file or directory
s@ubuntu:~$ nodejs --version
v0.10.25
s@ubuntu:~$
As you can see, when i do 'nodejs --version' it states I have version v0.10.25 ... So why does bin/init.sh give me a "Please install node v0.10" error?
How can this be? What do I do? I am pretty sure I was following all the instructions right.
Chunbo_H_Intel1
Could you tell me the node.js path on your system?
Stephen_-_
Is this what you mean?
s@ubuntu:~$ which nodejs
/usr/bin/nodejs
s@ubuntu:~$
Stephen_-_
I have been able to fix the problem by installing nodejs-legacy with
sudo apt-get install nodejs-legacy
Chunbo_H_Intel1
Sound good. One more thing is that currently we recommend node version with 0.10.38 or later versions.
Thanks!
aven
Thanks!
CS_WebRTC_Conference_Server_MCU.v3.0.1,Need Node.js version with 4 or later versions
output:
# ./init.sh
node version not match. Please use node v4
Chunbo_H_Intel1
Yes, Node v4 and above is required for our 3.0 release.
Please refer to the server user guide for more details.
Stephen_-_
Where is the conference server user guide located? I cannot find it.
I thought it might be here https://software.intel.com/en-us/webrtc-sdk-support
but it isn't.
I thought it might be within the Intel_CS_WebRTC.v3.0_Update2.zip
but it isn't.
Where is it!?
Also your statement about requiring "Node v4 and above" seems incorrect as I tried with node v5 and it failed but v4 worked fine.
edit: By luck I have found the user guide here: http://registrationcenter-download.intel.com/akdlm/irc_nas/8641/Intel_CS_WebRTC_User_Document.v3.0_Update2.zip
I really think you have to make this more obvious where to download though, I never found the link until I decided to play with the original download URL. What pages currently provide that link?
Chunbo_H_Intel1
Hi Stephen,
Sorry for the inconvenience. We're now working on putting all of our documentation online, so that you do not have to download them.anymore.
Regarding the specific question, it is in the section of "CS_WebRTC_Server_User_Guide.v3.0/md_servermd__server.html#Conferencesection2_3_1".
Thanks!
