Good morning, how can I update in real time the layout of a mixed stream through N.API.updateRoom?
- Tags:
- HTML5
- JavaScript*
I have the same question and would like to know if each user can have a different layout for the mixed stream..
Hi David,
Please take a look at the conferenceClient.getRegion and conferenceClient.setRegion functions. I think that's what you're looking for.
Please note that above functions does not change layout, it gets or sets the region for a specific stream in the pre-defined layout.
I was not clear enough in my question.
I'm trying to change the layout of the room and not the allocation of regions.
My goal is to switch between two custom layout (defined with my json) without having to re-join the room
大家好:
现在测试发现视频第一个画面始终被有声音的视频占用,这个是在哪里配置的呢,如何取消呢?
yongtao x. wrote:
大家好:
可以在createRoom或者updateRoom时把avCoordinate这个flag置成false,它控制了VAD的功能。
david c. wrote:
Hi, I was not clear enough in my question. I'm trying to change the layout of the room and not the allocation of regions. My goal is to switch between two custom layout (defined with my json) without having to re-join the room
Hi, David
Current multiple layouts are defined for the different participant number, layout changes along with the participant number change. For the same participant number, the multiple layout support will be available in next v3.4 release around late May.
Best wishes,
Zhai Lei
vi extras/basic_example/basicServer.js
add the following code:
app.post('/updateRoom/', function (req, res) { 'use strict'; N.API.updateRoom(req.body.rid,req.body.options, function (response) { res.send(response); },function (err) { res.send(err); }); });
javascript client:
updateRoom = function (roomId, name,enableMixing, publishLimit, userLimit,crop,resol,quality_level,multistreaming, callback) { var Options = { name: name, publishLimit: publishLimit, userLimit: userLimit, enableMixing: enableMixing, mediaMixing: { video: { //maxInput: 15, resolution: resol, multistreaming: multistreaming, quality_level:quality_level, crop: crop } } }; // ajax send method send(null, 'POST', "json", 'updateRoom/', false, {rid: roomId, options: Options}, function (err, text) { if (err) return clog(err, text); callback(text); }); }
conferenceClient.getRegion and conferenceClient.setRegion 这个接口是使用publish后的流对象ID吗? 返回错误告诉流ID不存在。
The first argument of getRegion and setRegion is an object. For getRegion, it should be something like {id: 'the stream id'}
conference.setRegion({
region: '1'
}, function() {
L.Logger.info('setRegion succeeded');
}, function(err) {
L.Logger.error('setRegion failed:', err);
INFO: local stream published: 888259284431114800
woogeen.sdk.js:590 INFO: subscribed: 5913d05f04c8f51456fe04a1
woogeen.sdk.js:590 ERROR: setRegion failed: Stream 888259284431114800does not exists
woogeen.sdk.js:590 INFO: stream added: 888259284431114800
是这样写法吗?还是返回不存在呢?
When do you setRegion? In the success callback of publish?
conference.publish(localStream, {}, function(stream) {
region: '1'
}, function() {
}, function(err) {
Lei Zhai (Intel) wrote:
Quote:
Hi, David
Best wishes,
Zhai Lei
Hi Lei,
When will a new version be released to introduce this new feature that support multiple layout in same conference?
setRegion 还是这个问题,断点到 SDK this.setRegion = function(a, c, d) { 就能设置成功,确实是在publish 成功后设置的窗口布局
Quote:
Hi, David
Best wishes,
Zhai Lei
Does version 3.4 implement the layout
switching function through the
viewports? Does this mean that I need
to alternate between the various
mixedstream of viewports for changing
layouts?
v3.4 released and multiple layouts can be specified for the same room and different mixed streams will be generated at the same time.
Hi, may I ask when the PublishLimit works? I found that if PublishLimit set as 1 or 0 in A room, all users joined in A room can publish success. why this happened?
Hi Lei,
In v3.4 when i enable multiple layouts, second subscribed video is empty. is there any specific configuration for the same
Naresh
Hi, Naresh
Thanks for raising this topic. v3.4 document is not good enough on this part. The published streams only exist in first common view port by default. Customers need to login as 'manger' role and use ConferenceClient.mix/unmix to control them whether exist in other layout/view port after publishing.
Best wishes,
Zhai Lei
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
