Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
Intel computing stick
Koul1994
Hii guyz.
I want to plug in the intel computing stick into my desktop and it should automatically play the video that I have in it. Is there a possibility to get this done?
Thank you
AlHill
Does your desktop have a HDMI input?  Probably not, unless you have some video capture card.  Otherwise, the Compute Stick requires a HDMI display/monitor/TV to use for video output.
Koul1994
AlHill
What has an HDMI?  Your desktop?  If so, that is for HDMI output.   The stick does HDMI output as well.  OUTPUT into OUTPUT does nothing.
AlHill
One thing, simple and easy, is if your desktop monitor has multiple HDMI INPUTS.  If so, plug your desktop into one of the monitor inputs, and the stick into another monitor input, and manually switch the monitor between the inputs.
Or, get an HDMI KVM, and use that to switch between the stick and desktop.
