Hi
It seems like Aria 10 Open CL nodes have errors:
1. When I select nodes for arria 10 openCL there are errors that was never there before:
-bash: /usr/bin/tclsh: No such file or directory
-bash: export: _moduleraw: not a function
-bash: export: module: not a function
2. Those errors causing several problems:
cannot write aocx bitstream to FPGA
Error enumerating AFCs: no driver available
Error parsing device name '▒▒▒▒'
aocl program: Running program from /opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
Error programming device
aocl program: Program failed.
and this error only exist in Aria 10 openCL nodes,
in Aria 10 oneAPI nodes, Stratix 10 nodes everything is fine
Good day to you.
Sorry for the inconvenience caused. We were able to find some issues with the Arria 10 OpenCL nodes as observed by you. We are working with the development team to get this resolved. Thanks for reporting the same and we will let you know when it is fixed.
Jyothis V James
