When trying to import TensorFlow in the cluster, I get the following error for the module pandas:
Traceback (most recent call last):
File "localcnn_sourceloc_01.py", line 13, in
from halcon_src import models, graph, coarsening, utils
File "../halcon_src/models.py", line 3, in
import tensorflow as tf
File "/glob/intel-python/python3/lib/python3.6/site-packages/tensorflow/__init__.py", line 24, in
from tensorflow.python import *
File "/glob/intel-python/python3/lib/python3.6/site-packages/tensorflow/python/__init__.py", line 77, in
from tensorflow.python.estimator import estimator_lib as estimator
File "/glob/intel-python/python3/lib/python3.6/site-packages/tensorflow/python/estimator/estimator_lib.py", line 32, in
from tensorflow.python.estimator.inputs import inputs
File "/glob/intel-python/python3/lib/python3.6/site-packages/tensorflow/python/estimator/inputs/inputs.py", line 23, in
from tensorflow.python.estimator.inputs.pandas_io import pandas_input_fn
File "/glob/intel-python/python3/lib/python3.6/site-packages/tensorflow/python/estimator/inputs/pandas_io.py", line 28, in
import pandas as pd
File "/glob/intel-python/python3/lib/python3.6/site-packages/pandas/__init__.py", line 40, in
import pandas.core.config_init
File "/glob/intel-python/python3/lib/python3.6/site-packages/pandas/core/config_init.py", line 14, in
import pandas.core.config as cf
File "/glob/intel-python/python3/lib/python3.6/site-packages/pandas/core/config.py", line 57, in
import pandas.compat as compat
AttributeError: module 'pandas' has no attribute 'compat'
I do not have this issue when running in my PC. I'm using Python 3.6 and TensorFlow 1.4.0.
I've checked for similar issues on online forums and apparently this problem can be solved by upgrading dask, however I do not have permission to do so. Can you please assist?
Thank you!
Thanks for reaching out to us, We tried the same in DevCloud (Login node and Computer node) . We didn't find any issues to import the packages you specified. Please have a check on the attached screenshots.
would be better if you can provide us the version of packages/libraries you are trying to use on Cluster such as tensorflow, pandas and other libraries version ,
Thanks & Regards,
Ratheesh A
Thanks & Regards,
Ratheesh A
![](/skins/images/05D335160E7CD666F354185C812BA28D/responsive_peak/images/icon_anonymous_message.png)
