Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1757 Discussions
Batch job exceeding wall time and qdel not working
MajdiAS
Yesterday I submitted a batch job to devcloud_login (S10PAC option). I set the walltime to 6 hours, however today I found that the job was still running with an elapsed time of 21 hours. I tried to kill the job using qdel to resubmit, however I was getting the following message "qdel: Server could not connect to MOM <job number>.v-qsvr-fpga.aidevcloud".
aikeu
Hi JyothisV_Intel,
I think this is a platform related issue so I will refer this thread to the devcloud FPGA platform team.
Aik Eu
JyothisV_Intel
Good day to you.
To assist you further, can you confirm which Intel DevCloud you are using? Is it Intel DevCloud for oneAPI or Intel DevCloud for Edge or Intel DevCloud for FPGA?
Jyothis V James
MajdiAS
Just an update, the job is still running, at 92 hours elapsed time.
MajdiAS
I am using the Intel DevCloud for FPGA, using the Stratix 10 (S10PAC option) specifically.
aikeu
Hi JyothisV_Intel,
Aik Eu
MajdiAS
Any updates on your side? I am still not able to kill the job (which has been running for 425 hours). I cannot use the kill -9 command as the qsub command does not show up. The qdel MOM issue is also still present.
Best,
Majdi
MajdiAS
The problem is now solved. Thank you.
JyothisV_Intel
Good day to you.
Sorry for the delay and glad to know that your issue is resolved. We will no longer monitor this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thanks and Regards,
Jyothis V James
