Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1465 Discussions
Binary path for pip and jupyter appears incorrect
asin
I've activated my own conda environment but am seeing problematic paths for pip. Same case for jupyter.
$which python
/home/<USER_NUMBER>/.conda/envs/lang_id_pytorch/bin/python
$ which pip
/glob/intel-python/python2/bin/pip
Why is it pointing to python2 and not my conda environment?
JaideepK_Intel
Thank you for posting in the intel communities.
We were able to reproduce your issue and we are working on this internally. We will get back to you with an update.
If you want to download any packages, please use pip3 instead of pip.
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
Good day to you.
Sorry to say this, but OneAPI DevCloud doesn't support Python2. Since pip is a Python2 package manager, you are facing this issue.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
