Good day to you.
Sorry for the inconvenience caused. Intel DevCloud is a shared environment which comes with pre-installed validated Intel oneAPI software and complimentary packages. As a policy, we do not install custom (open source or third party licensed) software to the environment and recommend that you explore available and equivalent oneAPI SW tools or components. Therefore, we cannot install screen command in Intel DevCloud.
Alternatively, you can use batch mode submission of jobs using job script to ensure a similar functionality as documented in the link below: https://devcloud.intel.com/oneapi/documentation/job-submission/
If you need any help in submitting jobs in batch mode, do get back to us.
If this answers your question, please click the “Accept as Solution” button to indicate that your issue is resolved.
Jyothis V James
Good day to you.
Jyothis V James
Good day to you.
Thanks for accepting the solution. We will no longer monitor this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Jyothis V James
