Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1757 Discussions
Facing problem when running the Intel Dev Cloud setup for XG Boost local setup
ashna_upadhyay
I am facing a problem while trying to run Intel Dev Cloud setup for XG Boost local setup. Please refer to the screenshot below. Let me know if you need any further information regarding this.
Ashna
AthiraM_Intel
We have informed the concerned team regarding this issue.
We could see that "AI_Kit_XGBoost_Predictive_Modeling" folder is present with in the /data folder.
Could you please run the below command and let us know whether you are referring to these samples or not?
! rsync -avhP /data/oneapi_workshop/AI_Kit_XGBoost_Predictive_Modeling/ ~/AI_Kit_XGBoost_Predictive_Modeling
If you have any further issue, please let us know.
AthiraM_Intel
Could you please let us know which sample you are trying? Are these samples a part of any Intel workshop?
Also share the complete steps to reproduce the issue
ashna_upadhyay
I am trying the samples under Intel's training modules, please refer to the screenshot below.
The notebook is under XG Boost > Local Setup.
Thanks!
AthiraM_Intel
ashna_upadhyay
Yes, I was referring to this.
Thanks!
Dan_P_Intel
In addition to the response above, you can use the following to update all training materials as necessary:
/data/oneapi_workshop/get_jupyter_notebooks.sh
AthiraM_Intel
For your information, the documentation is updated with the correct command.
! rsync -avhP /data/oneapi_workshop/AI_Kit_XGBoost_Predictive_Modeling ~/AI_Kit_XGBoost_Predictive_Modeling
Please find the below link with correct command:
https://github.com/oneapi-src/oneAPI-samples/blob/master/AI-and-Analytics/Jupyter/Predictive_Modeling_Training/AI_Kit_XGBoost_Predictive_Modeling.complete/00_Local_Setup/Local_Setup.ipynb
Since your issue resolved, can we close the case?
ashna_upadhyay
Thanks for your reply. Yes, you can close the case.
Ashna
AthiraM_Intel
Thanks for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
