Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1474 Discussions
devcloud intel for edge - opencv bug
Yuri_Zhavoronkov
Hello! When trying to test the code, I came across an error loading a JPG image via opencv. The image is not loading. (img == None) I got a similar error in jupyter oneApi, but there I updated the opencv-python package via %pip and this error went away. In devcloud intel for edge jupyter I can't update the package because no privileges. Any ideas how to fix the error?
Hari_B_Intel
Hi Yuri_Zhavoronkov,
Can I know the API you use to load the images?
In Intel® Developer Cloud for the Edge, you can use MatplotLib imshow() to load the images.
Further information can be obtained from OpenCV_Primer_Tutorial under the tutorial section.
Sample API to use MatplotLib imshow();
import cv2
import matplotlib.pyplot as plt
plt.figure() # create new image for display
plt.title('Loading Image')
imageRGB = cv2.cvtColor(imageBGR,cv2.COLOR_BGR2RGB)
plt.imshow(imageRGB)
Hope this information help
Thank you
Hari_B_Intel
import cv2
Thank you
Hari_B_Intel
Hi Yuri_Zhavoronkov
This thread will no longer be monitored since we have provided a solution. Please submit a new question if you need any additional information from Intel.
