Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1660 Discussions
CMake Configuration is broken on DevCloud
ArmyXn
I have a project that relies on CMake to build CUDA/ROCm/oneAPI binaries. While CMake can successfully find all the necessary oneAPI components (i.e. IntelDPCPP, oneDPL, MKL) on other systems after running:
source /opt/intel/oneapi/setvars.sh
It fails miserably on DevCloud with the following error:
$ CC=icx CXX=icpx cmake -S . -B build
-- Setting build type to 'Release' as none was specified.
-- The CXX compiler identification is IntelLLVM 2023.0.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found OpenMP_CXX: -fiopenmp (found version "5.0")
-- Found OpenMP: TRUE (found version "5.0")
-- The SYCL compiler is /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx
-- The SYCL Flags are -fsycl
-- The SYCL Language Version is 202001
-- Found IntelDPCPP: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/include (found version "202001")
CMake Error at CMakeLists.txt:68 (find_package):
  By not providing "FindoneDPL.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "oneDPL", but
  CMake did not find one.
  Could not find a package configuration file provided by "oneDPL" with any
  of the following names:
    oneDPLConfig.cmake
    onedpl-config.cmake
I tried to load oneDPL with 'module load dpl/latest' to no avail. Any idea how I can fix this?
Cheers,
Armin
ArmyXn
Thanks for letting me know. I have no other option than wait then. -Armin
fuzecate
I've been waiting to build a program on DevCloud. Is it possible to install Singularity/Apptainer on DevCloud so I can build it using oneAPI Singularity image?
JaideepK_Intel
Sorry for the delay, we are working along with the dev team on your issue.
Jaideep
ArmyXn
JaideepK_Intel
We got an update from Dev team, the issue is the cmake code is not following symlinks properly
it builds when oneapi is directly installed into /opt, which is why it works on a laptop and probably other tested cluster environments.
on Devcloud symlinks are used instead for /opt/intel and installed to a shared NFS directory
not tested but the user should get the code to properly follow symlinks and it will build successfully.
we can use the below command to load mkl on devcloud.
module load mkl/latest
One4all requires some dependencies that are not available on DevCloud; one of them is Catch2. To install Catch2 on Ubuntu, we use sudo apt install catch2.
On DevCloud, we cannot use sudo because of all these reasons. We are facing issues building the binaries.
Jaideep
ArmyXn
While on my laptop oneAPI is installed directly into /opt, on our clusters I've installed oneAPI on a luster filesystem and then symbolic linked the folder to ~/opt/intel/oneapi. Just by running 'source ~/opt/intel/oneapi/setvars.sh' CMake is able to generate the configuration successfully. In addition, CMake is a widespread tool for building software packages and that would be very unlikely that doesn't follow the symbolic links. So, I don't think that could be the source of the problem.
About one4all requiring catch2 (and also Google benchmark), as mentioned in the link below, if they're not installed, CMake script tries to fetch them from GitHub and build them:
https://github.com/arminms/one4all#building-from-source
So, you don't have to install them at all. On both my laptop and clusters, catch2 and Google benchmark are not installed but CMake does that flawlessly as part of the build process.
Armin
JaideepK_Intel
I hope you are doing well.
We got an update from Dev Team, they were able to build on a system with oneapi directly installed into /opt/intel without any symbolic links
we have a node available with oneapi directly installed into /opt/intel s001-n058.
you are welcome to use this node if it is available:
qsub -I -l nodes=s001-n058:ppn2:ppn=2
Jaideep
ArmyXn
Hi Jaideep,
Thanks for the update. During the past few days, I tried to use that node to no avail. It's not a matter of availability because even when I try to submit as a job (i.e. non-interactive) I get the following error:
$ qsub -l nodes=s001-n058:ppn2:ppn=2 build_one4all.sh
qsub: submit error (Job exceeds queue resource limits MSG=cannot locate feasible nodes (nodes file is empty, all systems are busy, or no nodes have the requested feature))
 Any suggestions?
Armin
JaideepK_Intel
We informed same to the engineering team and waiting for their update. Since anyone can access that node it's difficult to block specific nodes on DevCloud (unless they are free). We will get back to you once we get an update.
Jaideep
JaideepK_Intel
One of our engineering team members is directly contacting you, and they are attempting to use a Docker environment to support your benchmark tool.
So can we go ahead and close this case?
Jaideep
JaideepK_Intel
As mentioned above, one of our engineering team members is directly contacting you, and they are attempting to use a Docker environment to support your benchmark tool.
Jaideep
ArmyXn
No problem. Go ahead and close it.
Cheers,
Armin
JaideepK_Intel
Thank you for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
