# oneAPI DevCloud SSH config
Host devcloud
User u179515
IdentityFile ~/.ssh/devcloud-access-key-179515.txt
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-179515.txt guest@ssh.devcloud.intel.com
Host devcloud.proxy
User u179515
Port 4022
ProxyCommand ssh -T devcloud-via-proxy
# If you must route outgoing SSH connection via a corporate proxy,
# replace PROXY_HOSTNAME and PORT below with the values provided by
# your network administrator.
Host devcloud-via-proxy
User guest
Hostname ssh.devcloud.intel.com
LocalForward 4022 c009:22
ProxyCommand nc -x PROXY_HOSTNAME:PORT %h %p
# DevCloud VSCode config
Host devcloud-vscode
UserKnownHostsFile /dev/null
StrictHostKeyChecking no
Hostname localhost
User u179515
Port 5022
# SSH Tunnel config
Host *.aidevcloud
User u179515
ProxyCommand ssh -T devcloud nc %h %p
LocalForward 5022 localhost:22
LocalForward 5901 localhost:5901
EOF
Thank you for posting in Intel communities.
Are you trying ssh with proxy? If so, you have to update the config file by adding .proxy under SSH Tunnel config.
Please refer the attached screenshot.
Also please confirm whether you are able to connect Intel DevCloud using Cygwin terminal without using VSCode.
We have not heard back from you. Is your issue resolved?
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
