Hello
would be possible to get information about the memory DIMMs connected on the Xe Max nodes (e.g. s011-n005) ? I'm looking for the number of connected DIMMs, their respective size and operating speed - as reported by dmidecode -t 17, for instance. Since we cannot use root, I cannot collect these details.
Could you please tell us more about the use case, where you need more memory related information?
Please note that:
Current Terms and Conditions of using DevCloud do not allow benchmarking or publishing any related results.
For more information on the Terms & Conditions of DevCloud usage refer https://www.intel.com/content/www/us/en/legal/terms-of-use.html , Section 9.2 prohibits publishing performance benchmarks.
Abhijeet
We don’t provide root privileges to the user’s in the Intel Devcloud.
We are working on this with the concerned team to know if there is any alternative way to get information on memory DIMMs.
Abhijeet
You can use below command to list all compute nodes and their properties:
pbsnodes
To target specific nodes and properties use
grep properties
The properties are used to describe various capabilities available on the compute nodes like: CPU type & name, accelerator type and name, available DRAM, type of interconnect, number of accelerator devices available and their type and intended or recommended use.
To know more follow this link:
https://devcloud.intel.com/oneapi/documentation/job-submission/
Abhijeet
thank you for the information but this does not address my question. The pbsnodes (and its properties) report some high-level summary. However, it does not report the operating frequency of the memory and neither how many DIMMs are connected and their sizes.
Best.
Please note that:
Abhijeet
Oh! Thanks for pointing this out! I was unaware of this section in the terms&conditions!
Glad to know that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Abhijeet
