Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1738 Discussions
Enabling GPU_Jupyter Notebook
Goomanee__Salvish
Hello all,
I am trying to enable the GPU, I installed it via:
pip install tensorflow-gpu
and I am still not able to see if it's correctly installed.
The command
  1. import tensorflow as tf
  2. if tf.test.gpu_device_name():
  3.     print('Default GPU Device: {}'.format(tf.test.gpu_device_name()))
  4. else:
  5.     print("Please install GPU version of TF")
is retuning  "Please install GPU version of TF" and I don't understand.
Thanks for any help/recommendations!
Best,
S.
JananiC_Intel
Thanks for reaching out.
Devcloud does not have GPU but has iGPU installed in it.To get into iGPU node in devcloud try the below command.
qsub -X -I -l nodes=1:gpu:ppn=2
Also tensorflow-gpu is not supported in devcloud.
Hope this answers your question!
JananiC_Intel
Could you give us an update?
JananiC_Intel
We are closing the case assuming that your issues got resolved.Feel free to open a new thread if you face any further issues.
