Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1758 Discussions
Error displaying widget: model not found
e87tn95h
To whom it may concern,
Today, I just open Mandelbrot Demo ( /mandelbrot/mandelbrot.ipynb ) at Intel DevCloud for oneAPI, then run first cell "Device Selector".  The result is "Error displaying widget: model not found" instead displaying Radio Buttons.  Could you confirm it?
For now, it looks like issue of "jupyterlab-widgets" and/or "ipywidget" package installation. This issue is not critical/blocker, but it's NOT good.
Hiroshi
Dan_P_Intel
I would like to propose a workaround while the notebook gets fixed.
At this time the ipywidgets module is not loading for some reason.
In the "Build and Run" section, you need to replace:
  1. "{device.value}" to "GPU Gen9"
  2. code based on ipywidgets with the following:
    from IPython.display import Image
    Image('build/mandelbrot.png')
VaradJ_Intel
Good day to you.
Thanks for reporting this issue.
We were able to reproduce it and we have informed the development team about it.
Thank You.
Dan_P_Intel
VaradJ_Intel
Could you please give us an update?
Is the workaround provided by @Dan_P_Intel helpful to you?
If it resolves your issue, please make sure to accept it as a solution. This would help others with similar issues.
Thank you!
VaradJ_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thank You.
