Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1760 Discussions
Error when selecting an FPGA node
royak
Encountered this error when requesting a Strat10 node for an interactive session. (Screen shot attached). Is this simply because a node wasn't available at the time or is something else wrong? I am just trying to access the CCIP files (ccip_std_afu and ccip_interface_reg) in the OPAE/samples/hw directory to make sure our AFU is interacting correctly with them when synthesizing the build. Is there any other way I could access those files?
SreedeviK_Intel
The issue has been resolved. Could you please verify from your end and let us know?
Sreedevi
SreedeviK_Intel
Thank you for posting in Intel communities.
We are sorry for the inconvenience caused. We are checking with the concerned team on the same and will get back to you with an update shortly.
Sreedevi
SreedeviK_Intel
Sreedevi
SreedeviK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Sreedevi
