I tried all the method in this forums provide,
can not solve my problem.
u203142@devcloud: Permission denied (publickey).
- Tags:
- connect
Good day to you!
Please refer the following link to troubleshoot the issue:
If the issue still persists, reconfigure SSH connection as per the documentation below:
Linux/macOS: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
Windows: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-openssh/
If the provided steps do not resolve the issue, please provide us with the following information:
1) SSH configuration file located in .ssh folder which can be found at the following directories:
Windows: C:\Users\<username>\.ssh\config
Linux: ~/. ssh/config
2) Are you using proxy or VPN? Kindly try connecting after disabling proxy or VPN.
3) Exact steps/commands that you are using to connect to DevCloud.
Thasneem Vazim
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
i just give it up, and try to deploy locally
same problem in all my computer, many others meet but still not resolved by intel, its..
Apologies for the inconvenience caused. In order to assist you better, can you get back to us with the following information:
1) Delete the known host file located in "C:\Users\<username>\.ssh\known_hosts" and try reconnecting.
2) Complete output obtained when running ssh -v devcloud.
Additionally, we have reached out to you through internal communication. Kindly respond to the same.
Thasneem Vazim
We have not heard back from you. Could you please provide an update regarding the information we requested?
Thasneem Vazim
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
