Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1760 Discussions
The instructions to build and run the vector_add example aren't working for me
mrakgr
https://devcloud.intel.com/oneapi/get_started/baseToolkitSamples/
I am following the instructions here to run the hello world sample. I cloned the `oneAPI-samples` using git, went into the directory and created the relevant build.sh and run.sh files there. Submitting them to the job queue using...
qsub -l nodes=1:gpu:ppn=2 -d . build.sh
...doesn't seem to be actually doing anything.
It feels like there is something wrong with make, and even just running `make clean` or `make all `directly is telling me that no target is set.
Furthermore, the build scripts for the learnings modules work completely differently, and don't seem to even use make
Also...
qsub -I -l nodes=1:gpu:ppn=2 -d .
...when I try to run an interactive session, it starts the node and then quickly ejects me. This happens when done from both ssh and the Jupyter notebook terminal. Am I supposed to be doing something else in order to log into the interactive session?
I could try adapting the build scripts for the learning modules and get it to work that way, but before I do that, I want to understand what is going wrong here.
mrakgr
#!/bin/bash
mkdir build
cd build
cmake ..
make cpu-gpu
# make clean # will erase the executable.
./vector-add-buffers
Ok, I figured it out. The instructions in the readme.md file that comes with the sample are more on point and work for me. Also a tricky part of bash scripting is that the last statements needs to have a newline otherwise it won't be executed.
I can submit the above script as a job and it will get compiled and run correctly.
A point of confusion for me is still what is going on with the interactive sessions.
Also, VS Code's remote extension host keeps crashing whenever I log into the shell using it using the regular SSH settings, and won't login at all using the remote specific settings.
mrakgr
#!/bin/bash
mkdir build
cd build
cmake ..
make cpu-gpu
mrakgr
Rahila_T_Intel
Glad to know that your issue is resolved.
Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
