Error: The board package being used only supports report generation/emulation/runtime, please use the board package shipped in the FPGA addon instead.
Error: Exiting.
llvm-foreach:
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
any Help would be greatly Appreciated!
Hey Hari,
take a look at this topic:
https://community.intel.com/t5/Intel-DevCloud/Cannot-find-board-package-on-devcloud/td-p/1421143
Hey Hari,
Thanks for posting in Intel communities.
Did you get a chance to try out the solution which Christoph9 suggested, as given in the case https://community.intel.com/t5/Intel-DevCloud/Issue-on-fpga-compile-nodes/td-p/1418848 .
Could you please share the updates.
Thanks for your advice. With them I was able to successfully compile fpga-programs on the fpga_compile-nodes again.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
