Hello.
I copied "oneapi-tookit-development.zip" from "/data/..." and ran FPGA vector add program in it.
I followed instructions in
However, I get following error messages when I run it:
"run_fpga_hw.sh.e8560"---------------------------------------------------------------------------------------------------
libopae-c reconf.c:427:fpgaReconfigureSlot() **ERROR** : Failed to reconfigure bitstream: Input/output error libopae-c reconf.c:445:fpgaReconfigureSlot() **ERROR** : PR CRC error detected Error writing bitstream to FPGA: reconfiguration error libopae-c reconf.c:427:fpgaReconfigureSlot() **ERROR** : Failed to reconfigure bitstream: Input/output error libopae-c reconf.c:445:fpgaReconfigureSlot() **ERROR** : PR CRC error detected Error writing bitstream to FPGA: reconfiguration error make: *** [run_hw] Error 255
"run_fpga_hw.sh.o8560"---------------------------------------------------------------------------------------------------
... Copyright (C) 2009-2019 Intel Corporation. All rights reserved. Intel(R) VTune(TM) Profiler 2021.1-beta02 (build 604121) :: oneAPI environment initialized :: ./vector-add.fpga Caught a synchronous SYCL exception: No device of requested type available. 0 (CL_SUCCESS) If you are targeting an FPGA hardware, please ensure that your system is plugged to an FPGA board that is set up correctlyand compile with -DFPGA If you are targeting the FPGA emulator, compile with -DFPGA_EMULATOR. fail Makefile.fpga:22: recipe for target 'run_hw' failed
Can you help me?
Hi Jung,
Thanks for reaching out to us. Please provides details about your environment so that we can assist you with this.
Pradeep
I loggined in to devcloud server as user31536.
I didn't change any environments and just followed instructions in the "Getting started with Intel DevCloud for Intel oneAPI Projects".
Is this enough?
I'm in the same situation and got the same errors when trying to run vector-add on a FPGA.
Rafa.
I'm having the same problem. Even the "setvars.sh" script fails when trying to initialize the board:
$ source /opt/intel/inteloneapi/setvars.sh :: initializing environment ... advisor -- latest Copyright (C) 2009-2019 Intel Corporation. All rights reserved. Intel(R) Advisor 2021.1 (build 603889) ccl -- latest clck -- latest compiler -- latest libopae-c reconf.c:427:fpgaReconfigureSlot() **ERROR** : Failed to reconfigure bitstream: Input/output error libopae-c reconf.c:445:fpgaReconfigureSlot() **ERROR** : PR CRC error detected Error writing bitstream to FPGA: reconfiguration error daal -- latest debugger -- latest dev-utilities -- latest dnnl -- latest dpcpp-ct -- latest inspector -- latest Copyright (C) 2009-2019 Intel Corporation. All rights reserved. Intel(R) Inspector 2021.1 (build 603548) intelfpgadpcpp -- latest intelpython -- latest ipp -- latest itac -- latest mkl -- latest mpi -- latest pytorch -- latest tbb -- latest tensorflow -- latest vpl -- latest Configuring enviroment for VPL... Adding /opt/intel/inteloneapi/vpl/latest/include to CPATH... Adding /opt/intel/inteloneapi/vpl/latest/lib to LIBRARY_PATH and LD_LIBRARY_PATH... Setting VPL_EXTENSIONS_PATH to /opt/intel/inteloneapi/vpl/latest/lib vtune -- latest Copyright (C) 2009-2019 Intel Corporation. All rights reserved. Intel(R) VTune(TM) Profiler 2021.1-beta02 (build 604121) :: oneAPI environment initialized ::
I have tried to manually load the "default.aocx" using "aocl program" utility but it fails with the same error.
In my case the problem is intermittent. I was able to use the board correctly for a while, then I got the mentioned error and after a few days it disappeared on its own. Now it reappeared.
Federico
Hi, I'm in the same position and got the same issues when trying to run vector-add on an FPGA. Thanks,
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
