Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1703 Discussions
Getting error while compiling same Opticm6 environment commands in docker container.
dipti_thorat
In file included from ../../msw_platform_services/runtime_services/stdlib/inc/string.h(23),
                 from ../../3p_oss_bsd/bionic/src/libc/string/__memcpy_chk.c(30):
../../3p_oss_bsd/bionic/src/libc/include/string.h(32): catastrophic error: cannot open source file "stddef.h"
  #include <stddef.h>
compilation aborted for ../../3p_oss_bsd/bionic/src/libc/string/__memcpy_chk.c (code 4)
make[1]: *** [/local/bgowdakx/sg8_test/sofia-oe-buildsystem/poky/../../android/out/target/product/m7272trio_mphy/bootloader/M7272_TRIO_XMM7272_DVFS_VMM_REV_1.0_IOSM_RPC_NAND_userdebug/obj/bionic_libc_common/__memcpy_chk.o] Error 3
make[1]: Leaving directory `/local/bgowdakx/sg8_test/modem/system-build/make'
make: *** [bionic_libc_common.lib] Error 2
WARNING: exit code 2 from a shell command.
ERROR: Function failed: do_fls_image (log file is located at /local/bgowdakx/sg8_test/sofia-oe-buildsystem/build-m7272trio_mphy/tmp-m7272-trio-mphy/work/x86_64-linux/misc-fls-mini/1.0-r0/temp/log.do_fls_image.11218)
JyothisV_Intel
Good day to you.
From your query, we are not exactly sure what issue you are facing or the steps to replicate it from our side. To assist you better, can you get back to us with the following information:
1. Are you using Intel DevCloud? Is yes, is it Intel DevCloud for oneAPI or Intel DevCloud for Edge?
2. A sample reproducer code that replicates this error.
3. The exact steps/commands that you followed/executed that led you to this error.
Jyothis V James
dipti_thorat
--> I am using docker container with linux environment
I attached with same as build.log
->git config --global url."https://".insteadOf git://
->source setup-build-env-ext build -m m7272-trio-mphy -var m7272trio_mphy -d xmm7272-slim-nonatt -swv XMM7272_V2_TRIO_2043.00_BL01_DPACKS
->export PATH=`echo $PATH | sed 's/\:\.//g'`
->bitbake fota-mini 2>&1 | tee build.log
JyothisV_Intel
Good day to you.
Thanks for getting back to us.
This forum primarily supports queries related to Intel DevCloud. Kindly confirm if you are facing issues using any Intel products, hardware, software or services. If yes, do get back to us to assist you better with those products.
Jyothis V James
AnaWilliam850
Hi
The error message indicates that the file stddef.h could not be found by the compiler. This is likely because the necessary include path is not set up correctly.
Here are some steps you can try to resolve this issue:
  1. Check if the file stddef.h exists in the expected location. If it doesn't, make sure it is installed or copied to the appropriate directory.
  2. Check if the include path is set up correctly. You can do this by looking at the compiler command that was used to compile the code. Make sure that the necessary include paths are specified with the -I option.
  3. If you are using a build system or IDE, check the project settings to make sure that the include path is set up correctly.
  4. If the issue persists, try running a clean build to make sure that any cached files are cleared and the build system picks up the correct include path.
  5. If you are still unable to resolve the issue, try consulting the documentation or seeking help from the community or the toolchain support team.
dipti_thorat
Hi AnaWilliam850,
Thanks for your support. I will let you know after completion.
Thanks & Regards
Dipti
dipti_thorat
../../3p_oss_bsd/bionic/src/libc/include/string.h(69): error: identifier "size_t" is undefined
  extern size_t strnlen(const char *, size_t) __purefunc;
../../3p_oss_bsd/bionic/src/libc/include/string.h(70): error: identifier "size_t" is undefined
  extern char*  strncat(char *, const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/string.h(71): error: identifier "size_t" is undefined
  extern char*  strndup(const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/string.h(72): error: identifier "size_t" is undefined
  extern int    strncmp(const char *, const char *, size_t) __purefunc;
../../3p_oss_bsd/bionic/src/libc/include/string.h(73): error: identifier "size_t" is undefined
  extern char*  strncpy(char *, const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/string.h(75): error: identifier "size_t" is undefined
  extern size_t strlcat(char *, const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/string.h(76): error: identifier "size_t" is undefined
  extern size_t strlcpy(char *, const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/string.h(78): error: identifier "size_t" is undefined
  extern size_t strcspn(const char *, const char *) __purefunc;
../../3p_oss_bsd/bionic/src/libc/include/string.h(81): error: identifier "size_t" is undefined
  extern size_t strspn(const char *, const char *);
../../3p_oss_bsd/bionic/src/libc/include/string.h(86): error: identifier "size_t" is undefined
  extern size_t strxfrm(char *, const char *, size_t);
In file included from ../../msw_platform_services/runtime_services/stdlib/inc/string.h(26),
                 from ../../3p_oss_bsd/bionic/src/libc/include/stdlib.h(40),
                 from ../../msw_platform_services/runtime_services/stdlib/inc/stdlib.h(23),
../../msw_platform_services/runtime_services/stdlib/inc/stdlib.h(39): error: identifier "size_t" is undefined
  typedef size_t rsize_t;
In file included from ../../3p_oss_bsd/bionic/src/libc/include/stdlib.h(40),
../../msw_platform_services/runtime_services/stdlib/inc/string.h(264): error: identifier "size_t" is undefined
  size_t strnlen_s(const char *s, size_t maxsize);
In file included from ../../msw_platform_services/runtime_services/stdlib/inc/stdlib.h(23),
../../3p_oss_bsd/bionic/src/libc/include/stdlib.h(172): error: identifier "wchar_t" is undefined
  extern size_t   mbstowcs(wchar_t *, const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/stdlib.h(173): error: identifier "wchar_t" is undefined
  extern int      mbtowc(wchar_t *, const char *, size_t);
../../3p_oss_bsd/bionic/src/libc/include/stdlib.h(176): error: identifier "wchar_t" is undefined
  extern int    wctomb(char *, wchar_t);
../../3p_oss_bsd/bionic/src/libc/include/stdlib.h(177): error: identifier "wchar_t" is undefined
  extern size_t    wcstombs(char *, const wchar_t *, size_t);
In file included from ../../3p_oss_bsd/bionic/src/libc/string/__memcpy_chk.c(32):
../../3p_oss_bsd/bionic/src/libc/private/logd.h(31): catastrophic error: cannot open source file "stdarg.h"
  #include <stdarg.h>
make[1]: *** [/local/bgowdakx/2043_ZIP/sofia-oe-buildsystem/poky/../../android/out/target/product/m7272trio_mphy/bootloader/M7272_TRIO_XMM7272_DVFS_VMM_REV_1.0_IOSM_RPC_NAND_userdebug/obj/bionic_libc_common/__memcpy_chk.o] Error 3
Whole file is incorrect it's showing
JyothisV_Intel
Good day to you.
We have not heard back from you. This thread will no longer be monitored by Intel and all interactions in this thread will be community only.
Thanks and Regards,
Jyothis V James
