Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1773 Discussions
How do I connect VSCode to devcloud in windows
Nikhil_T
Hi there!
I am a new user to devcloud and I am unable to figure out how to connect to the devcloud in windows using VS Code. Can anyone please provide step by step procedure for the same. I tried following the steps mentioned for VS code but when I type ssh devcloud in the VS code terminal it says ssh: Could not resolve hostname devcloud: No such host is known.
AthiraM_Intel
Could you please share the configuration?
Also make sure that you have downloaded the right key. Please try to download the key manually and check again.
AthiraM_Intel
Please make sure that you have done all the configuration steps given in the following link to connect to DevCloud :
https://devcloud.intel.com/oneapi/documentation/connect-with-vscode/
This link provides all the steps with screenshot. Please make sure that you completed all the steps.
Also, you need to setup SSH config and the detailed steps are given in the following documentation :
https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
You can find the host name in the configuration file ./.ssh/config
For example , if this is the config file details :
Host devcloud
User uxxxxx
IdentityFile <path to key>/devcloud-access-key-xxxxx.txt
ProxyCommand ssh -T -i <path to key>/devcloud-access-key-xxxxx.txt guest@devcloud.intel.com
 Then do :
ssh devcloud
(the name corresponding to the Host is devcloud in first line )
Please provide the complete path for the key.
If you face any issue, please let us know.
AthiraM_Intel
Could you please give us an update? Is your issue resolved?
Nikhil_T
Hi there! (I am using the terminal of VS Code for all the command execution)
I did all the steps but I am unable to connect to the devcloud. FYI, I did the following :
1 ) Option 1 Automated Configuration : Ran the bash command and it resulted in the following:
The /root/.ssh directory for SSH client configuration already exists.
Appending SSH connection configuration to /root/.ssh/config
Creating the private SSH key /root/.ssh/devcloud-access-key-xxxxx.txt
Important: this file is your access key, keep it safe like you would a password.
Done! Now you can access Intel DevCloud by running ssh devcloud or, if you are behind a proxy, ssh devcloud.proxy
2 ) Then I did rm command for the cleanup
3) When I do ssh devcloud in the terminal of VS Code, it says the following:
These things were mentioned in https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
Could you please tell what could be the issue.
Nikhil_T
@AthiraM_Intel
I did ssh devcloud-vscode (since this was mentioned in the file) but it says :
ssh: connect to host localhost port 5022: Connection refused
Nikhil_T
I was able to resolve this issue. I was supposedly doing it in VS code when it should be done in cygwin. But now I face another issue:
When I do ssh devcloud in cygwin I get this:
$ ssh devcloud
ssh: connect to host devcloud.intel.com port 22: Connection timed out
kex_exchange_identification: Connection closed by remote host
Connection closed by UNKNOWN port 65535
AthiraM_Intel
Nikhil_T
@AthiraM_Intel  I am able to connect but it connect only a few times. Also, it gets disconnected after a few minutes.
Additionally , I want to ask that if I connect it through VSCode and I write code in the VSCode through SSH, if I run it in the VS code, does it run on the devcloud ?
AthiraM_Intel
Please make sure that the network is consistent.
Also share the screenshot of the error.
Regarding the second query, You can log into the Intel DevCloud by
ssh devcloud
There you can run your programs. It will run on DevCloud.
Nikhil_T
This is the error that I get when I do ssh devcloud
$ ssh devcloud
Sometimes it connects and stays there for like 30 mins but after that it closes automatically and says something like broken pipe error.
AthiraM_Intel
Could you please share the config file to check if there is any issue.
The connection loss after 30 minutes is due to no activity in the shell.
Nikhil_T
AthiraM_Intel
From your previous post we could see that, you were able to connect and facing issue of disconnection after 30 minutes.
That is due to no activity in the shell.
You can prevent ssh session from exiting.
In Cygwin we have "ServerAliveInterval" option , please check the below link for more information.
 https://superuser.com/questions/612401/keeping-cygwin-ssh-session-alive
Could you please let us know if you have any further issues.
AthiraM_Intel
Nikhil_T
Hi there! Yes I am able to connect via VS Code and Cygwin but with intermittent disconnections.
AthiraM_Intel
The disconnection is mainly due to network issues and no activity in the shell for a long time.
You could use nohup command to run the job. Nohup is a command in Linux systems that keep processes running even after exiting the shell or terminal.
Please use the below command to run your job file.
nohup qsub job &
You can view the output of your script in the nohup.out file, which is created while running the job.
For more information, you can refer below link:
https://community.intel.com/t5/Intel-DevCloud/client-loop-send-disconnect-Connection-reset-by-peer/m-p/1157550
Since your initial issue is resolved, can we close this thread?
AthiraM_Intel
Could you please let us know whether we can close this case?
AthiraM_Intel
We have not heard back from you, we wont be monitoring this thread. If you need further assistance, please post a new thread.
