I want to use the USM host memory allocation technique. But only FPGA boards that have a USM capable BSP (for example, the Intel® FPGA PAC D5005 with Intel Stratix® 10 SX with USM support: intel_s10sx_pac:pac_s10_usm) can support such a technique.
Just specify the Stratix10 cannot work in USM host allocation. like
qsub -I -l nodes=1:fpga_runtime:stratix10:ppn=2 -d .
So I want to ask how to specify such kind of device to compile and run.
Apologies for the delay in our response.
I just received feedback from the development team that USM is not supported.
USM will only be supported on s10/Stratix cards using oneAPI.
If the given response clarifies your query, make sure to accept this as a solution. This would help others with similar issue.
We are checking on this internally. We will get back to you soon.
Dont know if this still works but in the past I used the commands from this post:
We haven't heard back from you. Could you please give us an update.
Thanks for your reminder. Actually, I am trying to figure out the previous comment. Sorry for the late action.
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
