Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1689 Discussions
Not able to change conda environment
PBhar
When a user creates a new conda environment, he expects the environment to be be completely isolated from the global path. But in this case, the path remains fixed (/glob/intel-python/python3/bin//python)  and I'm not able to change.
I've attached the screenshot below.
PBhar
I tried it just now with the default environments.
qsub: waiting for job 557645.v-qsvr-1.aidevcloud to start
qsub: job 557645.v-qsvr-1.aidevcloud ready
#      Date:           Thu Mar 26 08:10:23 PDT 2020
#    Job ID:           557645.v-qsvr-1.aidevcloud
#      User:           u39403
# Resources:           mem=196gb,neednodes=4:ppn=2,nodes=4:ppn=2,walltime=24:00:00
(base) u39403@s001-n006:~$ conda info --envs
# conda environments:
base                  *  /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest
2021.1-beta05            /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/envs/2021.1-beta05
pytorch                  /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/envs/pytorch
pytorch-1.4.0            /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/envs/pytorch-1.4.0
tensorflow               /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/envs/tensorflow
tensorflow-1.15.0        /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/envs/tensorflow-1.15.0
torch                    /home/u39403/.conda/envs/torch
(base) u39403@s001-n006:~$ conda activate pytorch
(pytorch) u39403@s001-n006:~$ python3
Python 3.6.3 |Intel Corporation| (default, Feb 12 2018, 06:37:09)
[GCC 4.8.2 20140120 (Red Hat 4.8.2-15)] on linux
Type "help", "copyright", "credits" or "license" for more information.
Intel(R) Distribution for Python is brought to you by Intel Corporation.
Please check out: https://software.intel.com/en-us/python-distribution
>>> import torch
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'torch'
(pytorch) u39403@s001-n006:~$ conda activate pytorch-1.4.0
(pytorch-1.4.0) u39403@s001-n006:~$ python3
>>> import torch
Not sure how is it working on your end.
Dan_P_Intel
I have the same dilemma, not sure how it's not working on your end. ;)
Might be related to packages you've previously installed in your user space.
At this point I would look at a few options:
1. cleanup or refresh your side of things. You mentioned previously you installed some packages and perhaps there's a collision between various things.
To be fair I'm not an expert on Conda env management, so the following may or may not help:
https://docs.conda.io/projects/conda/en/latest/commands/clean.html
conda clean --yes --all
Remove custom environments:
conda remove --name myenv --all
etc. other related cleanup methods
2. You could give us permissions to enter your home folder and try and find a fix
3. We could try and reset your account to default but that may lead to lost files on your side.
Which option would you like to try?
PBhar
Yes, you have the permission. I'm tired of replying now. Please try it yourself and let me know if you figured out.
PBhar
I have two accounts. The one I'm referring to has User Name: u39403. The other one also has the same problem but I use it primarily.
Dan_P_Intel
No worries. I got that info from the terminal output you have posted previously. ;)
Would you mind if we simply backup your files and reset your account to factory settings? Might be faster than trying to debug what's going on.
PBhar
Please go ahead
Dan_P_Intel
Prajjwal, I've decided to wait a bit before going into your account.
Could you please try the following first?
1. mv ~/.conda ~/tmp/
if that does not help and there is pip involved, then
2. mv ~/.local ~/tmp/
Thank you!
PBhar
Done
Dan_P_Intel
Does Conda work now as you would expect it?
Thank you!
PBhar
I have not tried yet. I'll try using the instance and let you know any problems that I will encounter.
PBhar
No it's not working.
Please see below.
(base) u39403@login-2:~$ conda info --envs
WARNING: The conda.compat module is deprecated and will be removed in a future release.
base                  *  /glob/intel-python/versions/2018u2/intelpython3
(base) u39403@login-2:~$ q
qsub: waiting for job 561084.v-qsvr-1.aidevcloud to start
qsub: job 561084.v-qsvr-1.aidevcloud ready
#      Date:           Tue Mar 31 06:45:03 PDT 2020
#    Job ID:           561084.v-qsvr-1.aidevcloud
#      User:           u39403
(base) u39403@s001-n055:~$ conda create --name torch
Collecting package metadata (current_repodata.json): done
Solving environment: done
## Package Plan ##
  environment location: /home/u39403/.conda/envs/torch
Proceed (/n)? y
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
#     $ conda activate torch
# To deactivate an active environment, use
#     $ conda deactivate
(base) u39403@s001-n055:~$ conda activate torch
(torch) u39403@s001-n055:~$ conda install pytorch torchvision cpuonly -c pytorch
## Package Plan ##
  added / updated specs:
    - cpuonly
    - pytorch
    - torchvision
The following packages will be downloaded:
    package                    |            build
    cpuonly-1.0                |                0           2 KB  pytorch
    jpeg-9b                    |       h024ee3a_2         214 KB
    libtiff-4.1.0              |       h2733197_0         447 KB
    olefile-0.46               |           py37_0          50 KB
    pillow-7.0.0               |   py37hb39fc2d_0         598 KB
    pytorch-1.4.0              |      py3.7_cpu_0        39.0 MB  pytorch
    torchvision-0.5.0          |         py37_cpu        10.6 MB  pytorch
    zstd-1.3.7                 |       h0b5b093_0         401 KB
                                           Total:        51.2 MB
The following NEW packages will be INSTALLED:
  bzip2              conda_channel/linux-64::bzip2-1.0.8-0
  certifi            conda_channel/linux-64::certifi-2019.11.28-py37_0
  cpuonly            pytorch/noarch::cpuonly-1.0-0
  freetype           conda_channel/linux-64::freetype-2.10.1-1
  icc_rt             conda_channel/linux-64::icc_rt-2021.1b5-intel_387
  intel-openmp       conda_channel/linux-64::intel-openmp-2021.1b5-intel_387
  intelpython        conda_channel/linux-64::intelpython-2021.1b5-0
  jpeg               pkgs/main/linux-64::jpeg-9b-h024ee3a_2
  libffi             conda_channel/linux-64::libffi-3.3-11
  libgcc-ng          conda_channel/linux-64::libgcc-ng-9.1.0-hdf63c60_0
  libpng             conda_channel/linux-64::libpng-1.6.37-2
  libstdcxx-ng       conda_channel/linux-64::libstdcxx-ng-9.1.0-hdf63c60_0
  libtiff            pkgs/main/linux-64::libtiff-4.1.0-h2733197_0
  mkl                conda_channel/linux-64::mkl-2021.1b5-intel_336
  mkl-service        conda_channel/linux-64::mkl-service-2.3.0-py37_0
  mkl_fft            conda_channel/linux-64::mkl_fft-1.1.0-py37ha68da19_0
  mkl_random         conda_channel/linux-64::mkl_random-1.1.0-py37ha68da19_0
  ninja              conda_channel/linux-64::ninja-1.9.0-py37hfd86e86_0
  numpy              conda_channel/linux-64::numpy-1.17.5-py37ha68da19_1
  numpy-base         conda_channel/linux-64::numpy-base-1.17.5-py37_1
  olefile            pkgs/main/linux-64::olefile-0.46-py37_0
  openssl            conda_channel/linux-64::openssl-1.1.1d-0
  pillow             pkgs/main/linux-64::pillow-7.0.0-py37hb39fc2d_0
  pip                conda_channel/linux-64::pip-19.3.1-py37_2
  python             conda_channel/linux-64::python-3.7.5-hf484d3e_3
  pytorch            pytorch/linux-64::pytorch-1.4.0-py3.7_cpu_0
  setuptools         conda_channel/linux-64::setuptools-45.2.0-py37_0
  six                conda_channel/linux-64::six-1.13.0-py37_2
  sqlite             conda_channel/linux-64::sqlite-3.30.1-6
  tbb                conda_channel/linux-64::tbb-2021.1b5-intel_342
  tbb4py             conda_channel/linux-64::tbb4py-2021.1b5-py37_intel_0
  tcl                conda_channel/linux-64::tcl-8.6.9-24
  tk                 conda_channel/linux-64::tk-8.6.9-29
  torchvision        pytorch/linux-64::torchvision-0.5.0-py37_cpu
  wheel              conda_channel/linux-64::wheel-0.33.6-py37_4
  xz                 conda_channel/linux-64::xz-5.2.4-h14c3975_7
  zlib               conda_channel/linux-64::zlib-1.2.11.1-h14c3975_1
  zstd               pkgs/main/linux-64::zstd-1.3.7-h0b5b093_0
Proceed (/n)? y
Downloading and Extracting Packages
pillow-7.0.0         | 598 KB    | ############################################################################################################################################# | 100%
libtiff-4.1.0        | 447 KB    | ############################################################################################################################################# | 100%
cpuonly-1.0          | 2 KB      | ############################################################################################################################################# | 100%
olefile-0.46         | 50 KB     | ############################################################################################################################################# | 100%
torchvision-0.5.0    | 10.6 MB   | ############################################################################################################################################# | 100%
zstd-1.3.7           | 401 KB    | ############################################################################################################################################# | 100%
jpeg-9b              | 214 KB    | ############################################################################################################################################# | 100%
pytorch-1.4.0        | 39.0 MB   | ############################################################################################################################################# | 100%
(torch) u39403@s001-n055:~$ python3
>>> import torch
(torch) u39403@s001-n055:~$ which python
/glob/intel-python/python3/bin/python
Dan_P_Intel
Prajjwal,
Have you looked at the following getting started guide?
https://devcloud.intel.com/oneapi/get-started/analytics-toolkit/
It covers our recommended way of using the PyTorch and TensorFlow versions that are installed through the Intel® AI Analytics Toolkit(Beta).
with apologies, could you please try the following steps:
3. ssh devcloud
4. source /opt/intel/inteloneapi/setvars.sh
5. conda activate pytorch
The source .../setvars.sh command is required in order for this to work. We have added this command to the ~/.bash_profile of all (or at least most) users a while back but it seems that in your case that may not be true.
The AI DevCloud is being retired, I believe today is the last day. The old way of doing things on the DevCloud is not supported anymore.
PBhar
Please check your recommended solution before you inform me. You already have access to my account.
(base) u39403@s001-n055:~$ source /opt/intel/inteloneapi/setvars.sh
:: setvars has already been run. Skipping any further invocation.  To force its re-execution, pass --force
(base) u39403@s001-n055:~$  conda activate pytorch
(pytorch) u39403@s001-n055:~$ python3
>>> import torch
Dan_P_Intel
Good catch. Yes, you can't use the login node for your work.
You need to access a compute node.
Here's an updated list of instructions.
1. ssh devcloud
This will lead you to the login node.
2. mv ~/.conda ~/tmp/
3. mv ~/.local ~/tmp/
This was just to clean up your conda/pip environment.
4. qsub -I
Request an interractive session on a compute node.
Note: -I is upper case i not lower case L.
5. source /opt/intel/inteloneapi/setvars.sh
6. conda activate pytorch
The 4th step requests an interactive session on any compute node. This is great for debugging your projects but there's a better way if you want to execute some large workloads (for example ML training): the batch mode.
For more info about job submission see this link: https://devcloud.intel.com/oneapi/learn/job-submission/.
PBhar
Please carefully see what I posted. I tried your method, it doesn't work. I never asked about compute/login node. That's clearly evident from the snippet I shared. I'm again posting it here.
>>> import torch
Pytorch is not imported. This should not happen.
Dan_P_Intel
Somehow you're starting the system python not the intelpython from oneAPI despite of sourcing the setvars.sh. I can only assume that certain changes on your profile are hiding the intelpython. Any thoughts?
What would be a good time window for us to go in using your account? I'd like to avoid interfering with your work.
PBhar
Please go ahead (log in to my account). I'm not using it.
PBhar
Can you please print exact steps on how a user is supposed to create a fresh conda environment and install packages ? Please test it out properly. Whatever I receive on these forums are either half cooked solutions or they don't work at all.
PBhar
It seems that users can't install any packages now in intel provided environments.  They're greeted with this:
EnvironmentNotWritableError: The current user does not have write permissions to the target environment.
  environment location: /glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/envs/pytorch-1.4.0
Why are there so many restrictions ? Why can't a user do a fresh install by themselves ? I think docker support would be more handy rather than using what is provided.
Dan_P_Intel
Prajjwal, thank you for your patience.
I have accessed your account and found a conda initialization section in your .bashrc config file. This section configured the python in /glob/intel-python as your default python, a valid setting during the lifetime of AI DevCloud. Since the AI DevCloud was retired on 03/31/2020, the initialization section is not necessary anymore, at least in the current form.
In order to do some testing, I have commented out that initialization section and this time the steps I mentioned in a previous post passed. Please try it and let me know if that addresses your issue.
Based on your experience we're conducting additional investigations & fixes. One related issue we found is that after conda deactivate the oneAPI environment variables might be disabled. Our recommendation is to explicitly run "source /opt/intel/inteloneapi/setvars.sh" before any meaningful work.
As a thank you for your continuing efforts to improve the Intel(R) DevCloud we've extended your access by one additional year. Thank you!
AthiraM_Intel
Could you please confirm, whether the steps mentioned previously are working fine now?
