Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Pino inout
Soares
Como faço para um pino inout de um FPGA Cylone IV começar in, receber uma entrada IR, virar out, enviar um vetor com a entrada IR para um outro FPGA Cyclone IV, e depois voltar a ser in novamente?
Soares
Obs: A transmissão de dados entre os FPGAs se dá pelo protocolo RS232
DiyaN_Intel
We only provide support in English. We have translated your question.
"How do I make an inout pin on a Cylone IV FPGA start in, receive an IR input, turn out, send a vector with the IR input to another Cyclone IV FPGA, and then turn back in again?
 Note: Data transmission between FPGAs takes place via the RS232 protocol"
Does this reflect your question correctly and could you please provide us with a description of your issue?
To assist you further, could you please let us know which Intel Devcloud are you using:  Intel DevCloud for Edge or Intel DevCloud for oneAPI ?
Diya
DiyaN_Intel
We have not heard back from you.
Could you please reply to the above queries and details so that we can try to investigate the issue from our end?
Diya
DiyaN_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards,
Diya
