Is there any way to use 4th Gen Xeon SP in devcloud environment?
Regards, Kuni
The following are the 4th Generation Xeon Scalable Processors (SP) (codenamed Sapphire Rapids) available on Intel DevCloud for oneAPI:
$ pbsnodes | sort | grep spr | uniq -c
2 properties = xeon,spr,max9480,ram256gb,netgbe,batch,hbm
2 properties = xeon,spr,ram1024gb,netgbe,dnp50
You can use batch mode or interactive mode for requesting the above nodes using the below commands:
Batch mode:
$ qsub -l nodes=1:spr:ppn=2 -d . job_script.sh
Interactive mode:
$ qsub -I -l nodes=1:spr:ppn=2 -d .
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Sreedevi
I can use Gen 4 Xeon devcloud Environment and could get required data.
Thank you, Kuni
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Sreedevi
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
