Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1347 Discussions
Why decoding video with hardware acceleration is still slow on the devcloud
miserablefaith
i use sample_decode to decode an av1 video on devcloud, but it took a long time(almost 100 seconds) to decode. The size of this av1 video is 2MB.
when i run sample_decode on my linux, it takes just 6 seconds. i don't know why? Can someone please tell me?
AlekhyaV_Intel
Thank you for posting in Intel Communities. And thank you for sharing your observations with us. We would like to have some information from you to debug your issue further.
  1. Sample Code( We are assuming that you're using sample_decode from oneVPL library. If not, please provide the code and video file.
  2. Sample reproducer - the steps you've tried so that we can reproduce your issue.
  3. CMake version in your DevCloud.
And we have a quick suggestion for you: It is a known issue that iris_xe_max nodes are not working as expected and will be taken down from tomorrow i.e. 29th July, 2022. So we suggest you to try out in another gpu nodes and see if the issue persists.
Thank you,
Alekhya
AlekhyaV_Intel
Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We have not heard back from you, so we will close this thread now. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
