I've installed autosklearn locally using:
pip install auto-sklearn
But I get the following error whenever I try and use the fit function:
import autosklearn
import autosklearn.classification
#define the model
automl = autosklearn.classification.AutoSklearnClassifier(time_left_for_this_task=1200, n_jobs=1)
#train the model
automl.fit(features_train, target_train)
This is the error:
[ERROR] [2022-12-05 14:38:09,724:Client-AutoML(1):63847a06-74ed-11ed-b04d-5dc3c51ac30b] (' Dummy prediction failed with run state StatusType.CRASHED and additional output: {\'traceback\': \'Traceback (most recent call last):\\n File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/evaluation/__init__.py", line 397, in run\\n obj(**obj_kwargs)\\n File "/home/u157922/.local/lib/python3.9/site-packages/pynisher/limit_function_call.py", line 302, in __call__\\n tmp_dir.cleanup()\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 834, in cleanup\\n self._rmtree(self.name)\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 816, in _rmtree\\n _shutil.rmtree(name, onerror=onerror)\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 740, in rmtree\\n onerror(os.rmdir, path, sys.exc_info())\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 738, in rmtree\\n os.rmdir(path)\\nOSError: [Errno 39] Directory not empty: \\\'/home/u157922/tmp/tmpl7sxjn6a\\\'\\n\', \'error\': "OSError(39, \'Directory not empty\')"}.',)
File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/automl.py", line 765, in fit
self._do_dummy_prediction()
File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/automl.py", line 489, in _do_dummy_prediction
raise ValueError(msg)
ValueError: (' Dummy prediction failed with run state StatusType.CRASHED and additional output: {\'traceback\': \'Traceback (most recent call last):\\n File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/evaluation/__init__.py", line 397, in run\\n obj(**obj_kwargs)\\n File "/home/u157922/.local/lib/python3.9/site-packages/pynisher/limit_function_call.py", line 302, in __call__\\n tmp_dir.cleanup()\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 834, in cleanup\\n self._rmtree(self.name)\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 816, in _rmtree\\n _shutil.rmtree(name, onerror=onerror)\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 740, in rmtree\\n onerror(os.rmdir, path, sys.exc_info())\\n File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 738, in rmtree\\n os.rmdir(path)\\nOSError: [Errno 39] Directory not empty: \\\'/home/u157922/tmp/tmpl7sxjn6a\\\'\\n\', \'error\': "OSError(39, \'Directory not empty\')"}.',)
I've tried clearing out the 'tmp' directory -- but that does not resolve or change the error.
We were able to reproduce your issue from our end, we are working on this internally and get back to you with an update.
Jaideep
Thanks Jaideep. I appreciate the quick response.
Looks like something was modified in my environment because auto-sklearn was working today. I then tried to add PipelineProfiler:
pip install PipelineProfiler
And now auto-sklearn is broken again.
Ideally, both would be available by default. But at a minimum, I'd like to understand the steps to install and use them successfully.
Sorry for the delay. We are going to contact you privately via mail. Have a great day ahead.
Jaideep
