Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1798 Discussions
devcloud login: Internal Server Error
sonersteiner
I am trying to login to the devcloud via:
https://devcloud.intel.com/oneapi/
I get the following error:
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
Is something wrong? I am getting this error since a week now.
I have also registered to the new devcloud, might that be the problem?
Soner
sonersteiner
I have created an additional account with another email adress from me and can log in to the old devcloud.
I think, the reason why I can't login in to the old devcloud with my original email is that I have registered with the same email to the new intel devcloud which is still in beta as of now (2023-08-04) ! Because the problem with the login started just after I have registered to the new intel devlcoud.
Anyhow, I still need the old devcloud, and I am using the new email ID now.
Best,
Soner
DiyaN_Intel
Good day to you.
Internal Server error might be a temporary issue due to Intel DevCloud being very busy.
Could you please try accessing it after clearing your cache/cookies and see if the issue still persists?
If yes, please share your email-id so that we can try to investigate from our end.
Can you please be specific about which DevCloud are you using ,we have four types of DevCloud -
 Intel DevCloud for Edge
 Intel DevCloud for oneAPI
 Intel DevCloud for FPGA
 Intel Developer Cloud Beta
Diya
sonersteiner
Hi Diya,
no it doesn't help.
My login is soner.steiner@tuwien.ac.at
Best,
Soner
DiyaN_Intel
Thank you for providing the details.
We have raised your issue to the development team and will get back to you at the earliest once your issue is fixed.
Diya
DiyaN_Intel
Could you please try accessing the login page after clearing your cache/cookies in incognito mode and see if the issue still persists?
Diya
sonersteiner
Hello Diya,
like I already wrote in the previous msg, I have already did clear the cache and the problem still  persists.
Best,
Soner
DiyaN_Intel
Sorry to say that we were not able to figure out where exactly the issue is with your account and maybe it is due to VPN issues.
Can you try with a different email-id probably a Gmail account and try to log in with it?
If you face any issues please connect back to us.
If this resolves your issue, make sure to accept this as a solution.
This would help others with similar issues. Thank you!
Diya
sonersteiner
Best,
Soner
DiyaN_Intel
We apologize for asking you again. The below two statements seem to contradict us.
>> I have created an additional account with another email address from me and can log in to the old DevCloud.
>> Anyhow, I still need the old DevCloud, and I am using the new email ID now.
Please answer the below questions so that we debug your issue further:
1 . We could see that you've created a new DevCloud account with a different email address.
But as per this statement (Anyhow, I still need the old DevCloud), are you unable to access the old DevCloud?
2. It Seems like you've accepted our response as a solution, have you done it by mistake?
Diya
sonersteiner
Hi, maybe I was not very clear.
I have my old email with my account, this is also connected to my instructor dashboard. With this account I can not login in to the old devcloud, because I have also registered to the new devcloud (still beta) with this email account.
Then I have created another account from another email of mine, with this I can login in to the old devcloud. This is good, because I still need the old devcloud.
So for now, I am set although I have two accounts now.
Best,
Soner
DiyaN_Intel
Seems like your issue is resolved. Can we go forward and close this thread?
Diya
sonersteiner
My issue is resolved.
Best,
Soner
DiyaN_Intel
Thanks for accepting our solution.
Glad to know that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya
priyansh1
Hi
I have facing same issue
I tried to login devcloud oneapi
And I get internal server error
My email: pjain2@cougars.ccis.edu
Please help me
sonersteiner
Hi priyansh1,
I had to create another account for the old devcloud.
My original account works now for the new intel devcloud.
I think you have to create a new account!?
Best
