Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1703 Discussions
has intel Devcloud installed CUDA?
yLiu56
I wonder has intel Devcloud installed CUDA?
if the answer is yes
what is the path of CUDAHOME?
can I install CUDA as a guest?
Intel Dev Cloud has not installed CUDA.
Regarding the question on installation of CUDA as guest, will check and get back to you.
Anju
yLiu56
From our understanding, CUDA works with GPUs, whereas DevCloud consist of high performing Intel Xeon Skylake CPUs. Hence installing CUDA won't be an appropriate action in DevCloud.
Dona
