First create a virtual environment using the below command
conda create -n -c intel python=2 pip numpy source activate
Command to install pytorch
conda install pytorch-cpu torchvision -c pytorch
Go to python shell and import using the command
import torch Thanks, Dilraj
Thanks for the guide line....but will you please make it clear where (which prompt) to form the virtual environment
In the terminal please give the below command
conda create -n Vaidehi -c intel python=2 pip numpy Virtual Name : Vaidehi Thanks, Dilraj
I could instal pytorch using steps you gave.
But import torch still did not work in jupyter notebook, it worked though on python shell accessed under virtual environment
one more doubt regarding jupyter:
how to save and submit script file prepared using jupyter ?
Please find the details
source activate conda install ipykernel ipython kernel install --name --user
Once this is done, launch your python code from hub.colfaxresearch.com
Select Kernel -> Change Kernel ->
Do try out and check if this works!
Dilraj
We did not receive any response, so we are closing the case for now.
Dilraj
Thanks, it worked....it didn't give me any error when i imported pytorch from jupyter notebook
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
Topic Options
