pip install --user <package>
is not working in openapi devcloud terminal.
Ill be thankful u help me in this case
Thanks for posting in Intel communities.
Could you please try to install the package using pip3 instead of pip.
pip3 install --user <package>
Please let us know if you are facing any issues.
thx for ur response
No, it hasnt solved!
Could you please try installing the package after creating a conda environment.
Please follow the below steps:
1. Create a conda environment:
conda create -n env_name python=3.7
2. Activate the environment:
source activate env_name
3. Install the package:
If the issue still persists please let us know.
Hi
it says
conda: command is not found
seems it has allergic to every command!
You can resolve the issue by activating the oneAPI environment before installing the package.
Please find the below command to activate the oneAPI environment:
source /opt/intel/inteloneapi/setvars.sh --force
Please make sure that the python used is "/glob/development-tools/versions/oneapi/<version>/oneapi/intelpython/latest/bin/python" using below command
which python
We have not heard back from you. Could you please give an update?
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
