Dear Devcloud admin and support
when I install any user python package i got the following error, you can use the following command to reproduce the error :
python3 -m pip install tqdm --user
File "/glob/intel-python/python3/lib/python3.6/runpy.py", line 183, in _run_module_as_main
mod_name, mod_spec, code = _get_module_details(mod_name, _Error)
File "/glob/intel-python/python3/lib/python3.6/runpy.py", line 142, in _get_module_details
return _get_module_details(pkg_main_name, error)
File "/glob/intel-python/python3/lib/python3.6/runpy.py", line 109, in _get_module_details
__import__(pkg_name)
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/__init__.py", line 26, in <module>
from pip.utils import get_installed_distributions, get_prog
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/utils/__init__.py", line 27, in <module>
from pip._vendor import pkg_resources
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 3018, in <module>
@_call_aside
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 3004, in _call_aside
f(*args, **kwargs)
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 3046, in _initialize_master_working_set
dist.activate(replace=False)
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2578, in activate
declare_namespace(pkg)
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2152, in declare_namespace
_handle_ns(packageName, path_item)
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2092, in _handle_ns
_rebuild_mod_path(path, packageName, module)
File "/glob/intel-python/python3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2121, in _rebuild_mod_path
orig_path.sort(key=position_in_sys_path)
AttributeError: '_NamespacePath' object has no attribute 'sort'
thank you,
W
Could you please try installing the package after creating a conda environment.
Please follow the below steps:
1. Create a conda environment:
conda create -n env_name python=3.6
2. Activate the environment:
source activate env_name
3. Install the package:
If the issue still persists please let us know.
hello AThiraM,
I tried your steps but received same error, Is there any solution without using conda ?
thank you, I appreciate your help!
regards,
W
When I try to run pip it's shows errors
And also while running conda
login-2:~$ conda install -c conda-forge tqdm
-bash: /glob/intel-python/python2/bin/conda: /glob/intel-python/versions/2018u2/intelpython2/bin/python: bad interpreter: No such file or directory
login-2:~$ pip install --user telethon
-bash: /glob/intel-python/python2/bin/pip: /glob/intel-python/versions/2018u2/intelpython2/bin/python: bad interpreter: No such file or directory
u222313@login-2:~$ conda create -n env_name python=3.6
I can even install any python package everytime it shows same things both in terminal and jypter notebook
You can activate the oneAPI environment before installing the package.
Please find the below command to activate the oneAPI environment:
source /opt/intel/inteloneapi/setvars.sh
Please make sure that the python used is "/glob/development-tools/versions/oneapi/beta09/inteloneapi/intelpython/latest/bin/python" using "which python" command.
Also you can try to install the tqdm package using conda:
If the issue still persists please share your user id and give us the permission to access your DevCloud account. We will inform the concerned team.
Could you please give us an update? Is your issue resolved?
We have not heard back from you, we wont be monitoring this thread. If you need further assistance, please post a new thread.
Hello Athira,
the system still report the same error.
I found there are some solutions for the same problem on the following links :
https://stackoverflow.com/questions/47955397/pip3-error-namespacepath-object-has-no-attribute-sort
https://github.com/googleapis/google-cloud-python/issues/2990
I don't have privilege to the system to try these solutions
thank you for your help and support.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
