When I using routing commad "qsub -I" to dispatch a new job today (1/29), the working node is not started as usual.
By using "qstat -Q" command, it returns as follow, please check, thanks!
Queue Max Tot Ena Str Que Run Hld Wat Trn Ext T Cpt
flex 30 0 yes yes 0 0 0 0 0 0 E 0
extended 0 0 yes yes 0 0 0 0 0 0 E 0
temp 2 0 yes yes 0 0 0 0 0 0 E 0
jupyterhub 0 0 yes yes 0 0 0 0 0 0 E 0
batch 200 67 yes yes 64 2 1 0 0 0 E 0
Same problem.
Same problem, job queue seems to be stuck.
Maybe an outage or maintenance? Is there any way to know about server status?
Jupyter session also constantly returns "Spawn failed: Timeout"
The command pbsnodes would check the status of servers.
Some servers are online, but my jobs are also stucked.
Facing the same issue for the last 9 hrs.
Same problem here, jobs submitted will not run and i cannot start up the server for jyupter devcloud.
I also have this problem. In my case I try to get a job running on a Stratix10 node. qstat -Q shows me that there are 110 jobs queued in total but only 3 running
Same here, with interactive jobs on the "spr" and the "icx" nodes, and batch jobs on the former.
We are sorry for the inconvenience caused. We are working on this issue internally. We will let you know the updates soon.
The issue is resolved now. Could you please check from your end whether the issue resolved for you and let us know.
Glad to know that the issue is resolved. The issue is resolved and we have verified the same from our end also.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
@free2ride19
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
