Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1758 Discussions
run as root user
jpei
Can I run as root user in dev cloud terminal? what are the password for it?
JananiC_Intel
Thanks for reaching out.
In Intel Devcloud, you don't have root access but you can run your workloads with Intel optimized frameworks and libraries without root access.Please find the below devcloud documentation for your reference
https://devcloud.intel.com/oneapi/get_started
jpei
Thanks for the respond.
I found out the EIS are advance application on devCloud. However, the feature such as TLS, manageability and so on are not found on devCloud. May I setup EIS on devCloud under Connect and Create?
JananiC_Intel
Since the DevCloud is a worldwide resource with ~4300 users we generally do not allow users to setup their own EIS or TLS connection methods. We have provided ssh & Jupyter entry points that all of our users are using without any conflicts with other users. we suggest using existing capabilities.
JananiC_Intel
Did that help?Do you have any updates?
JananiC_Intel
We are assuming that the solution provided helped and would no longer be monitoring this issue. Please raise a new thread if you have any further issues.
Janani Chandran
ARIANDEXAPY
Hi There Is No Complete root for devcloud but You Can Access A Limited PRoot Distro Root (Its A Docker-Like Root) its made for a game panel but you cat at least get a clean distro in user space:
https://github.com/ysdragon/Pterodactyl-VPS-Egg/raw/main/entrypoint.sh
