Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
Does Intel Python runs on AMD Opteron Processor?
sergio_r_
Intel Python distribution was successfully installed on a machine operating with an AMD Opteron Processor  running under Ubuntu 16.04. The Intel Python crash when importing numpy as shown below:
aeternam@salva:~$ python
Python 3.6.2 |Intel Corporation| (default, Aug 15 2017, 16:14:26)
[GCC 4.8.2 20140120 (Red Hat 4.8.2-15)] on linux
Type "help", "copyright", "credits" or "license" for more information.
Intel(R) Distribution for Python is brought to you by Intel Corporation.
Please check out: https://software.intel.com/en-us/python-distribution
>>> import numpy
Illegal instruction (core dumped)
aeternam@salva:~$
So, I am wondering whther Intel Python works on Opteron processors?
Sergio
Enhance your #MachineLearning and #BigData skills via #Python #SciPy
1) https://www.packtpub.com/big-data-and-business-intelligence/numerical-and-scientific-computing-scipy-video
2) https://www.packtpub.com/big-data-and-business-intelligence/learning-scipy-numerical-and-scientific-computing-second-edition
Robert_C_Intel
The problem is most likely some unexpected combination of supported ISA. Please try
gdb python
run
import numpy
And do "x/i $pc" when it crashes and show us the output.  Also the output of 'cat /proc/cpuinfo'
sergio_r_
Hi Robert,
gdb is not being helpful. The output I am getting is not related to the intel python installed in the system (see below).
In case it helps, I am also attaching the file intel_python_dump.txt with the output from strace python.
aeternam@salva:~$ gdb python
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.5) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from python...done.
(gdb) import sys
Undefined command: "import".  Try "help".
(gdb) python
>import sys
>print(sys.version)
>import numpy
>quit()
>3.5.2 (default, Sep 14 2017, 22:51:06)
[GCC 5.4.0 20160609]
Traceback (most recent call last):
  File "<string>", line 3, in <module>
ImportError: No module named 'numpy'
Error while executing Python code.
(gdb) qit
Undefined command: "qit".  Try "help".
(gdb) quit
Sergio
Robert_C_Intel
After you type 'gdb python', you have to type 'run' to start python, then you can 'import numpy' to see the error
(root) rscohn1@fxsatlin01$ gdb python
(gdb) run
Starting program: /localdisk/work/rscohn1/miniconda3/bin/python
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Python 3.5.2 |Continuum Analytics, Inc.| (default, Jul  2 2016, 17:53:06)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-1)] on linux
sergio_r_
Hi Robert, sorry for this delay in responding. The gdb output is as follows:
aeternam@panita:~$ gdb python
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.04) 7.11.1
(gdb) run
Starting program: /home/aeternam/myProg/Intel_Python_2018_0018/intelpython3/bin/python
>>> import numpy
Program received signal SIGILL, Illegal instruction.
0x00007ffff2d6af38 in __intel_sse4_strlen ()
   from /home/aeternam/myProg/Intel_Python_2018_0018/intelpython3/lib/python3.6/site-packages/numpy/core/../../../../libintlc.so.5
(gdb) exit
Undefined command: "exit".  Try "help".
(gdb) quit
A debugging session is active.
	Inferior 1 [process 3554] will be killed.
Quit anyway? (y or n) y
aeternam@panita:~$
Hope this helps to resolve the issue.
Sergio
Robert_C_Intel
Hi Sergio,
Intel Python requires a CPU that has SSE 4.2 instruction support. You can check if your linux system has it by doing:
cat /proc/cpuinfo | grep sse4_2
Opteron processors from ~ 2012 have it: https://en.wikipedia.org/wiki/List_of_AMD_Opteron_microprocessors
Robert
sergio_r_
Thanks Robert. That seems to be the problem. The opteron I am using for this project only has sse and sse2. Fortunately the Python Anaconda distribution works fine in such processor.
salut,
Sergio
