Update from conda with problem...
conda update --all
The following packages will be DOWNGRADED:
setuptools: 36.5.0-py36h65f9e6e_0 --> 27.2.0-py36_intel_0 intel [intel]
連結已複製
Didn't completely understand the issue you are facing. Are you telling, you were able to proceed and the update idp cond env was successfully?
I'm currently using IDP python 3.6 and have conda updated to 4.4.7 version.
Will you be able to share more details? "conda info" would do
I can explain: every day I check if it came out update for python modules, including the intel python, but after updating Conda and trying to check if it has update I get this indication that I should go back to previous versions ...
I assume you have intel channel in your .condarc file, so when packages are updated, intel channel takes precedence over defaults and there could be certain packages not updated in intel channel unlike the defaults.
When you are using Intel Distribution for Python, I would advise to have the latest versions available only in intel channel, although the package versions are older than that ones available in defaults to avoid any conflicts in dependencies . try to update your conda with "conda update --all -c intel"
So for the issue that I see here, this might resolve your problem
step 1. conda update -n base conda
updates root conda package manager based on defaults channel
step 2. conda update --all -c intel
upgrades/downgrades packages in IDP environment based on latest versions available in intel channel
Thanks for answer me.
I tried with:
Solving environment: done
The following packages will be downloaded:
ruamel_yaml-0.15.35 | py36hfa6e2cd_1 260 KB
Should I go back to the old version of Conda?
Andre,
The conda solver has thousands of dependencies to attempt to resolve when executing a command such as "conda update all," and I have often found the results puzzling. Often, the best way I have found to find out *why* conda is *not* installing a package I think it should (such as conda=4.4.7 in your case) is to explicitly request that version:
> conda install conda=4.4.7
Asking for that version specifically will force the solver to give that package version the highest priority. If the problem with that version is an actual dependency conflict, you should get a good hint in the response as to which dependent package is causing the conflict. Sometimes, the reason the other version was chosen was a "preference", not a hard requirement, and in that case the explicit install command will work.
So, please try the statement above to install the specific conda version you want and send us the response if it is unsuccessful.
Best, Todd
Thanks for help me. But I already installed the latest version of Conda.
The problem is that after update the Conda I try get Updates I get only old versions of packages (even in Intel channel):
conda: 4.4.7-py36_0 --> 4.4.6-py36_0
It is like if the List of packages for Intel Distribution work only with old version of Conda.
Andre,
It is difficult to troubleshoot without a list of the exact commands you are issuing and the conda environment that is active. Can you attach the output of "conda list"?
If I understand you correctly, when you execute "conda update conda" you get 4.4.7, but when you later issue "conda update --all" it downgrades conda to 4.4.6. Is that correct? If so, try using "conda update conda --all" or, if that does not work, "conda update conda setuptools --all". Those should tell the solver the keep the latest conda (and setuptools) version while updating all others.
I cannot test it without a snapshot of your environment, so if the suggestion does not work, please attach the output of "conda list".
Best, Todd
Microsoft Windows [versão 10.0.17074.1002] (c) 2017 Microsoft Corporation. Todos os direitos reservados. C:\Users\andre>conda update conda --all Solving environment: done ## Package Plan ## environment location: C:\IntelPython3 added / updated specs: - conda The following packages will be DOWNGRADED: conda: 4.4.7-py36_0 --> 4.4.6-py36_0 setuptools: 36.5.0-py36h65f9e6e_0 --> 27.2.0-py36_intel_0 intel [intel] Proceed (/n)? n C:\Users\andre>conda update conda setuptools --all Solving environment: done ## Package Plan ## environment location: C:\IntelPython3 added / updated specs: - conda - setuptools The following packages will be downloaded: package | build ---------------------------|----------------- ruamel_yaml-0.15.35 | py36hfa6e2cd_1 260 KB The following packages will be UPDATED: ruamel_yaml: 0.11.14-py36h9b16331_2 --> 0.15.35-py36hfa6e2cd_1 The following packages will be DOWNGRADED: conda: 4.4.7-py36_0 --> 4.4.6-py36_0 setuptools: 36.5.0-py36h65f9e6e_0 --> 27.2.0-py36_intel_0 intel [intel] Proceed ( /n)? n C:\Users\andre>conda list # packages in environment at C:\IntelPython3: # asn1crypto 0.22.0 py36_0 intel backports 1.0 py36_intel_6 [intel] intel backports.weakref 1.0rc1 py36_0 bkcharts 0.2 py36h7e685f7_0 bleach 1.5.0 py36_intel_0 [intel] intel bokeh 0.12.13 py36h047fa9f_0 bzip2 1.0.6 vc14_intel_13 [vc14 intel] intel cairo 1.14.10 ha12b3d8_6 certifi 2017.7.27.1 py36_intel_0 [intel] intel cffi 1.10.0 py36_intel_0 [intel] intel chardet 3.0.4 py36_intel_0 [intel] intel click 6.7 py36hec8c647_0 cloudpickle 0.5.2 py36h6b1d831_0 colorama 0.3.9 py36_intel_0 [intel] intel conda 4.4.7 py36_0 conda-env 2.6.0 h36134e3_1 cryptography 2.0.3 py36_intel_0 [intel] intel cycler 0.10.0 py36_intel_5 [intel] intel cython 0.27.1 py36_intel_0 [intel] intel daal 2018.0.1.20171012 1 intel dask 0.16.1 py36_0 dask-core 0.16.1 py36_0 decorator 4.1.2 py36_intel_0 [intel] intel distarray 0.6.0 py36_intel_4 [intel] intel distributed 1.20.2 py36_0 django 1.11.8 py36hd476221_0 django-filter 1.1.0 <pip> djangorestframework 3.7.3 <pip> entrypoints 0.2.3 py36_intel_0 [intel] intel EoN 0.98.2 <pip> freetype 2.8 vc14_intel_0 [vc14 intel] intel get_terminal_size 1.0.0 py36_intel_5 [intel] intel hdf5 1.10.1 vc14_intel_0 [vc14 intel] intel heapdict 1.0.0 py36h21fa5f4_0 html5lib 0.9999999 py36_0 icc_rt 2018.0.0 intel_1 [intel] intel icu 58.2 ha66f8fd_1 idna 2.6 py36_intel_0 [intel] intel impi_rt 2018.0.1 intel_2 [intel] intel intelpython 2018.0.0 3 intel ipykernel 4.6.1 py36_intel_0 [intel] intel ipyparallel 6.0.2 py36_intel_0 [intel] intel ipython 6.1.0 py36_intel_0 [intel] intel ipython_genutils 0.2.0 py36_intel_0 [intel] intel ipywidgets 7.0.0 py36_intel_0 [intel] intel jinja2 2.9.6 py36_intel_0 [intel] intel jsonschema 2.6.0 py36_intel_0 [intel] intel jupyter_client 5.1.0 py36_intel_0 [intel] intel jupyter_console 5.1.0 py36_intel_0 [intel] intel jupyter_core 4.3.0 py36_intel_1 [intel] intel libpng 1.6.32 vc14_intel_0 [vc14 intel] intel libprotobuf 3.4.1 h3dba5dd_0 llvmlite 0.20.0 py36_intel_0 [intel] intel locket 0.2.0 py36hfed976d_1 markdown 2.6.9 py36_0 markupsafe 1.0 py36_intel_0 [intel] intel matplotlib 2.0.2 np113py36_intel_1 [intel] intel menuinst 1.4.10 py36h42196fb_0 mistune 0.7.4 py36_intel_1 [intel] intel mkl 2018.0.1 intel_4 intel mkl_fft 1.0.0 np113py36_intel_15 [intel] intel mkl_random 1.0.0 np113py36_intel_6 [intel] intel mpi4py 2.0.0 py36_intel_15 [intel] intel mpmath 0.19 py36_intel_5 [intel] intel msgpack-python 0.5.1 py36he980bc4_0 nbconvert 5.2.1 py36_intel_0 [intel] intel nbformat 4.4.0 py36_intel_0 [intel] intel networkx 2.0 <pip> nose 1.3.7 py36_intel_16 [intel] intel notebook 5.0.0 py36_intel_0 [intel] intel numba 0.35.0 py36_intel_0 [intel] intel numexpr 2.6.2 np113py36_intel_5 [intel] intel numpy 1.13.3 py36_intel_6 [intel] intel openmp 2018.0.0 intel_8 intel openssl 1.0.2l vc14_intel_0 [vc14 intel] intel packaging 16.8 py36ha0986f6_1 pandas 0.20.3 np113py36_intel_4 [intel] intel pandocfilters 1.4.1 py36_intel_0 [intel] intel partd 0.3.8 py36hc8e763b_0 path.py 10.3.1 py36_intel_0 [intel] intel pickleshare 0.7.4 py36_intel_1 [intel] intel pip 9.0.1 py36_intel_0 [intel] intel pixman 0.34.0 hcef7cb0_3 prompt_toolkit 1.0.15 py36_intel_0 [intel] intel protobuf 3.4.1 py36h07fa351_0 psutil 5.4.3 py36hfa6e2cd_0 pycairo 1.13.3 py36h21e00d2_1 pycosat 0.6.3 py36h413d8a4_0 pycparser 2.18 py36_intel_0 [intel] intel pydaal 2018.0.1.20171012 np113py36_intel_1 [intel] intel pygments 2.2.0 py36_intel_1 [intel] intel pyopenssl 17.2.0 py36_intel_0 [intel] intel pyparsing 2.2.0 py36_intel_0 [intel] intel pysocks 1.6.7 py36_intel_0 [intel] intel pytables 3.4.2 np113py36_intel_2 [intel] intel python 3.6.3 intel_3 [intel] intel python-dateutil 2.6.0 py36_intel_3 [intel] intel pytz 2017.2 py36_intel_3 [intel] intel pywin32 221 py36h9c10281_0 pyyaml 3.12 py36_intel_3 [intel] intel pyzmq 16.0.2 py36_intel_4 [intel] intel requests 2.18.4 py36_intel_0 [intel] intel rpy2 2.8.6 <pip> ruamel_yaml 0.11.14 py36h9b16331_2 scikit-learn 0.19.0 np113py36_intel_6 [intel] intel scipy 1.0.0 <pip> scipy 0.19.1 np113py36_intel_23 [intel] intel setuptools 36.5.0 py36h65f9e6e_0 simplegeneric 0.8.1 py36_intel_5 [intel] intel six 1.10.0 py36_intel_8 [intel] intel sortedcontainers 1.5.9 py36_0 sqlite 3.20.1 vc14_intel_0 [vc14 intel] intel sympy 1.1.1 py36_intel_0 [intel] intel tbb 2018.0.1 py36_intel_4 [intel] intel tblib 1.3.2 py36h30f5020_0 tcl 8.6.4 vc14_intel_17 [vc14 intel] intel tensorflow 1.2.1 py36_0 testpath 0.3.1 py36_intel_0 [intel] intel tk 8.6.4 vc14_intel_26 [vc14 intel] intel toolz 0.9.0 py36_0 tornado 4.5.2 py36_intel_0 [intel] intel traitlets 4.3.2 py36_intel_1 [intel] intel urllib3 1.22 py36_intel_0 [intel] intel vc 14.0 2 intel vs2015_runtime 14.0.25420 0 wcwidth 0.1.7 py36_intel_5 [intel] intel werkzeug 0.14.1 py36_0 wheel 0.29.0 py36_intel_5 [intel] intel widgetsnbextension 3.0.2 py36_0 intel win_inet_pton 1.0.1 py36_intel_0 [intel] intel win_unicode_console 0.5 py36_intel_0 [intel] intel wincertstore 0.2 py36h7fe50ca_0 xz 5.2.3 vc14_intel_0 [vc14 intel] intel yaml 0.1.7 hc54c509_2 zict 0.1.3 py36h2d8e73e_0 zlib 1.2.11 vc14_intel_3 [vc14 intel] intel C:\Users\andre>
Hi andre,
I would clone the environment ("conda create --name myclone --clone myenv"), downgrade the packages that are prompted and once that is complete, upgrade to conda 4.4.7.
hope that works.
-preethi
Preethi V. (Intel) wrote:
Hi Andre,
Is this issue resolved?
-Preethi
The Last update of Python Distribution the Conda fix all problems of "conda updated --all"
but now the backend : TkAgg of matplotlib crashes Python after to close the Figure window
Hi andre,
Can you send the reproducer. I ran a sample code in IDP U2 on windows 10 and backed worked fine for me.
# -*- noplot -*- import matplotlib as mpl import numpy as np import sys if sys.version_info[0] < 3: import Tkinter as tk else: import tkinter as tk import matplotlib.backends.tkagg as tkagg from matplotlib.backends.backend_agg import FigureCanvasAgg def draw_figure(canvas, figure, loc=(0, 0)): """ Draw a matplotlib figure onto a Tk canvas loc: location of top-left corner of figure on canvas in pixels. Inspired by matplotlib source: lib/matplotlib/backends/backend_tkagg.py """ figure_canvas_agg = FigureCanvasAgg(figure) figure_canvas_agg.draw() figure_x, figure_y, figure_w, figure_h = figure.bbox.bounds figure_w, figure_h = int(figure_w), int(figure_h) photo = tk.PhotoImage(master=canvas, width=figure_w, height=figure_h) # Position: convert from top-left anchor to center anchor canvas.create_image(loc[0] + figure_w/2, loc[1] + figure_h/2, image=photo) # Unfortunately, there's no accessor for the pointer to the native renderer tkagg.blit(photo, figure_canvas_agg.get_renderer()._renderer, colormode=2) # Return a handle which contains a reference to the photo object # which must be kept live or else the picture disappears return photo # Create a canvas w, h = 300, 200 window = tk.Tk() window.title("A figure in a canvas") canvas = tk.Canvas(window, width=w, height=h) canvas.pack() # Generate some example data X = np.linspace(0, 2.0*3.14, 50) Y = np.sin(X) # Create the figure we desire to add to an existing canvas fig = mpl.figure.Figure(figsize=(2, 1)) ax = fig.add_axes([0, 0, 1, 1]) ax.plot(X, Y) # Keep this handle alive, or else figure will disappear fig_x, fig_y = 100, 100 fig_photo = draw_figure(canvas, fig, loc=(fig_x, fig_y)) fig_w, fig_h = fig_photo.width(), fig_photo.height() # Add more elements to the canvas, potentially on top of the figure canvas.create_line(200, 50, fig_x + fig_w / 2, fig_y + fig_h / 2) canvas.create_text(200, 50, text="Zero-crossing", anchor="s") # Let Tk take over tk.mainloop()
worked. Look for Attach picture ...
But my script didn't work (pictures)... I get this sample of Matplotlib site:
import numpy as np import matplotlib.pyplot as plt import matplotlib.animation as animation def data_gen(t=0): cnt = 0 while cnt < 1000: cnt += 1 t += 0.1 yield t, np.sin(2*np.pi*t) * np.exp(-t/10.) def init(): ax.set_ylim(-1.1, 1.1) ax.set_xlim(0, 10) del xdata[:] del ydata[:] line.set_data(xdata, ydata) return line, fig, ax = plt.subplots() line, = ax.plot([], [], lw=2) ax.grid() xdata, ydata = [], [] def run(data): # update the data t, y = data xdata.append(t) ydata.append(y) xmin, xmax = ax.get_xlim() if t >= xmax: ax.set_xlim(xmin, 2*xmax) ax.figure.canvas.draw() line.set_data(xdata, ydata) return line, ani = animation.FuncAnimation(fig, run, data_gen, blit=False, interval=1, repeat=False, init_func=init) plt.show(block = False)
Edited: The problem was the Pyzo editor... bad version! In iPython the Script works very well !
