Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
pip3 install intel-numpy has done, but still fails to import numpy
zhu__mario
I have installed intel-numpy by comand: pip3 intall intel-numpy, and i never installed any other numpy before this,
then run command: pip3 show intel-numpy, it shows below information:
Version: 1.15.1
Summary: NumPy optimized with Intel(R) MKL library
Home-page: https://software.intel.com/en-us/articles/empowering-science-with-high-performance-python
Author: Intel Corporation
Author-email: scripting@intel.com
License: Proprietary - Intel
Requires: icc-rt, mkl-random, mkl, tbb4py, mkl-fft
Required-by: mkl-random, mkl-fft
Maybe it turns out that intel-numpy has been installed successfully,
but when entering python3 console, run command: import numpy as np, it show the below information:
  File "<stdin>", line 1, in <module>
ImportError: No module named 'numpy'
Could you give me some help about this issue?
Mario
Todd_T_Intel
Mario,
Please send the output of pip3 list so I can see what else is in the environment. Also, did you install any other packages after the "pip3 install intel-numpy" command?
Todd
Krunal_Lathiya
This is a common problem if you install numpy versions with intermixed pip and numpy dependencies in an environment.  Can you post your conda list and conda info output for me to look at if you are using conda?
It may be possible that ip has not collected one of the dependencies right then.  You'll need to remove the packages from /site-packages/numpy/ and try to again install Numpy.  Multiarray is a common failure in NumPy if the installation fails to install correctly.
MilanPatel
It may be possible that ip has not collected one of the dependencies right then.  You'll need to remove the packages from /site-packages/numpy/ and try to again Here is Guide to install numpy Multiarray is a common failure in NumPy if the installation fails to install correctly.
