- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have problem to run 2019R3 myriad plugin with PCI boards. I can run the same sample program with NCS2 USB stick and there is no problem to run 2019R2 with both NCS2 and PCIe boards.
Error symptom :
Xeon server + Mustang-V100-MX8 + openvino_2019.3.344 binary package
$ ~/inference_engine_samples_build/intel64/Release/classification_sample_async -m ~/openvino_models/ir/FP16/public/squeezenet1.1/squeezenet1.1.xml -i /opt/intel/openvino/deployment_tools/demo/car.png -d MYRIAD
[ INFO ] InferenceEngine:
API version ............ 2.1
Build .................. custom_releases/2019/R3_cb6cad9663aea3d282e0e8b3e0bf359df665d5d0
Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ] /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
MYRIAD
myriadPlugin version ......... 2.1
Build ........... 30677
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
E: [ncAPI] [ 429564] [classification_] ncDeviceOpen:859 Device doesn't appear after boot
[ ERROR ] Can not init Myriad device: NC_ERROR
ARM64 box + AI Core XM2280 + openvino built for aarch64 from the source cloned on Oct 4th
$ ~/inference_engine_samples_build/arm64/Release/classification_sample_async -m ~/openvino_models/ir/FP16/public/squeezenet1.1/squeezenet1.1.xml -i /opt/intel/openvino/deployment_tools/demo/car.png -d MYRIAD
Build .................. custom_master_adc0d2784e316837c67cc30d85dfd23a44928131
MYRIAD
Build ........... custom_master_adc0d2784e316837c67cc30d85dfd23a44928131
E: [ncAPI] [ 168581] [classification_] ncDeviceOpen:854 Failed to find booted device after boot
It seems that there is some issue to initializing Myriad X device, and I am now look into plugin source code. I can find "Failed to find booted device after boot" string in dldt/inference-engine/thirdparty/movidius/mvnc/src/mvnc_api.c but I cannot find "Device doesn't appear after boot" sring in the cloned source tree.
Does anyone look at the issue?
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am having the same issue as well.
Run ./security_barrier_camera_demo -d myriad -d_va myriad -d_lpr myriad -i /opt/intel/openvino_2019.3.334/deployment_tools/demo/car_1.bmp -m /home/ubuntu/openvino_models/ir/FP16/intel/vehicle-license-plate-detection-barrier-0106/FP16/vehicle-license-plate-detection-barrier-0106.xml -m_lpr /home/ubuntu/openvino_models/ir/FP16/intel/license-plate-recognition-barrier-0001/FP16/license-plate-recognition-barrier-0001.xml -m_va /home/ubuntu/openvino_models/ir/FP16/intel/vehicle-attributes-recognition-barrier-0039/FP16/vehicle-attributes-recognition-barrier-0039.xml
[ INFO ] /opt/intel/openvino_2019.3.334/deployment_tools/demo/car_1.bmp
[ INFO ] Loading device myriad
myriad
[ INFO ] Loading detection model to the myriad plugin
E: [ncAPI] [ 208269] [security_barrie] ncDeviceOpen:859 Device doesn't appear after boot
Error on or near line 210; exiting with status 1
Is there anyone that can help this out.
Thank you
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Dear KWEK, PENG HONG and OKI, HIdetaka,
I will file a bug on both of your behalf.
Sorry for the inconvenience you are facing. I will keep you up-to-date on this forum.
Shubha
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Create a Ubuntu 18.04.3 LTS VM 2vCPU/w4Gb using VMWorkstation 15.5 on Win10 i7(4C/8T) w/16Gb -6th Gen and installed OpenVINO R3 and demos work with out NCS2.
Requirements: software.intel.com/en-us/openvino-toolkit/documentation/system-requirements
Note: NCS2 Requirements Ubuntu 16.04 (which I assume might now be out of date with OpenVINO R3 just released):
Then attached NCS2 to USB and VMWare prompts to connect to Ubuntu 18
Tried:
./demo_squeezenet_download_convert_run.sh -d MYRIAD
and
sudo -E ./demo_squeezenet_download_convert_run.sh -d MYRIAD
Resulting with error and being prompted to attach VSC Loopback
Run Inference Engine classification sample
Run ./classification_sample_async -d MYRIAD -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/bill/openvino_models/ir/FP16//public/squeezenet1.1/squeezenet1.1.xml
MYRIAD
E: [ncAPI] [ 203432] [classification_] ncDeviceOpen:859 Device doesn't appear after boot
Error on or near line 239; exiting with status 1
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Dear folks:
there is zero chance for users to have a native PCIe board. Currently no such boards exist on the market yet.
In particular Mustang-V100-MX8 from this forum post is the HDDL-R8 card and it works as a USB over PCIe device.
So you must either follow the HDDL or USB Myriad-X setup instructions to get things to work properly.
Thanks for your patience !
Shubha
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am getting the same error
Running ./benchmark_app -m ~/intel/openvino/deployment_tools/tools/model_downloader/public/vgg16/FP16/vgg16.xml -i input1.jpg -d MYRIAD
[Step 1/11] Parsing and validating input arguments
[ WARNING ] -nstreams default value is determined automatically for a device. Although the automatic selection usually provides a reasonable performance,but it still may be non-optimal for some cases, for more information look at README.
[Step 2/11] Loading Inference Engine
[ INFO ] Device info:
MYRIAD
[Step 3/11] Reading the Intermediate Representation network
[ INFO ] Read network took 1821.21 ms
[Step 4/11] Resizing network to match image sizes and given batch
[ INFO ] Network batch size: 1, precision: FP16
[Step 5/11] Configuring input of the model
[Step 6/11] Setting device configuration
[Step 7/11] Loading the model to the device
W: [ncAPI] [ 398792] [benchmark_app] ncDeviceOpen:651 Failed to find a device, rc: X_LINK_DEVICE_NOT_FOUND
I have followed all the installation steps with the Myriad Plugin but still getting this error
Can this issue be solved?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Aditya,
Can you please provide the specs of your system so that I can reproduce this issue?
Sahira
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi
I am running OpenVINO 2019 R3 on Ubuntu Linux 16.04
Intel Core i5 6500 CPU
Intel HD graphics 530 GPU
I am using the Intel Movidius MV0235 board with MA2485 Myriad X connected via ARM-USB-TINY-H JTAG
Aditya
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I understand that available Myriad X PCIe boards use PCIe-USB bridge device and I suppose required configuration should be set.
I have not yet solve the issue, but I aquire some additional information for further investigation.
> ARM64 box + Two AI Core XM2280 boards + openvino built for aarch64 from the source cloned on Oct 4th
ARM64 box + Two Mustang-M2BM-MX2 + openvino built for aarch64 from the source cloned on Oct 4th
I replaced AAEON borads to IEI boards for deploying AAEON board to thermal environment evaluation, and error symptom is same.
I noticed that the sample program runs fine when installing only one M.2 boads. But the error occurs when adding one more M.2 board.
line 925 in dldt/inference-engine/thirdparty/movidius/mvnc/src/mvnc_api.c
// Device should disappear from unbooted list
if (X_LINK_DEVICE_NOT_FOUND != XLinkFindFirstSuitableDevice(
X_LINK_ANY_STATE,
deviceDescToBoot,
&tempDevicDescr)) {
continue;
} else {
device_disappear = 1;
With one M.2 board XLinkFindFirstSuitableDevice() returns X_LINK_DEVICE_NOT_FOUND, but it returns X_LINK_SUCCESS with two boards and do loop (from line 817 to line 851) contimues untill timeout.
WIth one board - two Myriad X, beforeBootDevices[].name are "4-ma2480", "1-ma2480", and afterBootDevices[].name are "4-", "1-ma2480".
WIth two boards - four Myriad X, beforeBootDevices[].name are "4-ma2480", "1-ma2480", "4-ma2480", "1-ma2480", and afterBootDevices[].name are "4-", "1-ma2480", "4-ma2480", "1-ma2480". Mustang- M2BM-MX2 board has ID dip switch and I set different ID for each board. DeviceDesc.name are duplicated, but I am not sure it would affect the issue.
Regarding Xeon server + Mustang-V100-MX8 I have been trying to run with additional mvLog() , but inference engine compiled from github source does not run with the popular "/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64/libinference_engine.so: undefined symbol: _ZN3tbb10interface78internal15task_arena_base24internal_max_concurrencyEPKNS0_10task_arenaE" error somehow. I am now trying to fix it first.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I tried 2019R3.1 and compiled dldt cloned on Oct 30th. The result is same as 2019R3 case.
When running myriad Plugin on Xeon server (HPE Proliat DL380 Gen10) + Mustang-V100-MX8,
XLinkFindFirstSuitableDevice() at line 833 in dldt/inference-engine/thirdparty/mvnc/src/mvnc_api.c
returns X_LINK_SUCCESS , and do-while loop line 824-856 continues until timeout.
beforeBootDevices[].name are :
"2-ma2480" ,
"1-ma2480" ,
"2-ma2480" ,
"1.3-ma2480" ,
"2-ma2480" ,
"1-ma2480" ,
"2-ma2480" ,
"1-ma2480"
and afterBootDevices[].name are :
"2-" ,
"1-ma2480" ,
"2-ma2480" ,
"1.3-ma2480" ,
"2-ma2480" ,
"1-ma2480" ,
"2-ma2480" ,
"1-ma2480" ,
