[2022.1] Fail to add custom layer
Shiyu_Jin
I have followed the steps here https://docs.openvino.ai/2022.1/openvino_docs_Extensibility_UG_Intro.html to add a new op and try to use tool mo with --extension to load onnx, but it have following error:
OpenVINO does not support the following ONNX xxx:xxxx
I have succeed to add a op in version 2020.3. It seems that it is more simple than the old version because it only needs to add one class which inherits class ov::op::Op, but it doesn't work. So is there anything wrong ?
Peh_Intel
Hi Shiyu,
We notice that you’ve posted the same issue in our GitHub thread. As such, we will proceed to close this thread. Please allow our developer to have some time for the investigation. Further discussions regarding this issue can be done in the following GitHub thread:
https://github.com/openvinotoolkit/openvino/issues/12754
Sincerely,
Peh
