6579 Discussions
About SSD quantification bugs bugs by OpenVINO Post-Training Optimization Tool (POT)
jacky0327
Nouveau contributeur I
2 712 Visites
The new problem I encountered, the quantization of ssd-mobilenet-v2 failed to obtain the correct mAP, the error is as follows, please refer to the attachment link for details.
pot -c ssd_mobilenet_v2_license_plate_new_raw_pos_300x300_0525_qtz.json --output-dir backup -e
INFO:compression.algorithms.quantization.default.algorithm:Computing statistics finished
INFO:compression.algorithms.quantization.default.algorithm:Start computing statistics for algorithms : MinMaxQuantization,FastBiasCorrection
INFO:compression.pipeline.pipeline:Finished: DefaultQuantization
INFO:compression.pipeline.pipeline:Evaluation of generated model
INFO:compression.engines.ac_engine:Start inference on the whole dataset
Total dataset size: 30
30 objects processed in 0.488 seconds
INFO:compression.engines.ac_engine:Inference finished
INFO:app.run:map : 0.0
INFO:app.run:AP@0.5 : 0.0
INFO:app.run:AP@0.5:0.05:95 : 0.0
Please help me experiment and teach me how to solve it. Maybe my .json is wrong. Thank you for your careful help!!!
0 Compliments
7 Réponses
IntelSupport
Administrateur
2 688 Visites
Hi Jacky0327,
Thanks for reaching out. We have tested your model and currently investigating it. We will update you with further information soon.
Aznie
0 Compliments
jacky0327
2 679 Visites
Hello, I changed the COCO Dataset format to the VOC format, and it can work normally.
Please help confirm whether the quantified file (.json) has any errors.
If there are any points that need to be corrected or reinforced, please let me know ,Thank you!
Please refer to my attachment link.
0 Compliments
IntelSupport
Administrateur
2 644 Visites
Hi Jacky0327,
Thank you for your patience. Here are our findings. The error derived from the generated annotation file whereby the SSD model predicts classes started by 1 while val.json contains all objects with class 0. This has resulted that the metric defined cannot find any matches detected by class and return the result as 0. This can be resolved by adding the parameter has_background:true in the annotation_conversion section in the quantization/accuracy checker config:
 "annotation_conversion": {
          "converter": "mscoco_detection",
          "annotation_file": "quantization_coco_ask/license_plate/annotations/val.json"
"has_background": true
Once changed, you will manage to obtain the results like the screenshot below.
Some additional input, there is a small bug in the script where "license plate" is a single class name which consists of 2 words, but in categories, it was defined as {0: "license", 1: "plate"}, however, this is minor and does not influence on model accuracy.
Aznie
jacky0327
2 630 Visites
@IntelSupport
Hello, I am glad you can reply to me,
Regarding your answer, I understand. When I modify the json in your way, I get exactly the same result, nothing has changed at all.
Regarding the script for generating val.json, I have also changed it to license_plate, making her the first class.
Could you please share your modified json for my own reference?
I may not need accuracy_checker.yml, I need pot.json, thank you.
The instructions I gave are as follows:
0 Compliments
IntelSupport
Administrateur
2 617 Visites
Hi Jacky0327,
From your screenshot I noticed you are putting the has_background parameter in the preprocessing part. You have to put the has_background parameter inside the annotation_conversion part as below:
Aznie
0 Compliments
jacky0327
2 585 Visites
Thank you
Completely solve my problem!
IntelSupport
Administrateur
2 562 Visites
Hi Jacky0327,
I am glad to hear that. Therefore, this thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
0 Compliments
Répondre
