6594 Discussions
Any plan to support custom batch size or batch inference?
As title, I know the batch size is fixed to 1 while conversion currently.
I wonder if there is a chance that this constraint would be changed in the future?
@amacs.mist At the moment, there are no plans to change the batch size. With NCSDK v 2.04, you can now pipeline inferences from several networks on a single ncs device using the new fifo class. You can read more about it for the Python API at https://movidius.github.io/ncsdk/ncapi/python_api_migration.html and here is some example code https://github.com/movidius/ncappzoo/blob/ncsdk2/apps/image-classifier/image-classifier.py.
