6572 ディスカッション
Anyone get the Enet segmentation model running on OpenVino?
DaveInPA
新規コントリビューター I
1,956件の閲覧回数
Hi - I've been working on an application that uses the Enet architecture and the default trained model that the authors provided. That model was generated in Lua/Torch which isn't supported directly by OpenVino. So i followed the OpenVino docs to expert to the Torch model (.net file) to ONNX but ran into many problems there and assume thats not possible without modifying the underlying Torch model itself. I found other models out there in caffe but also couldn't get it to compile into a pre-trained model.
Just wondering if anyone out there has a pre-trained ENet based model (hopefully trained on city-scapes) that is workign with OpenVino (and hopefulyl Neural Compute stick)?
0 件の賞賛
6 返答(返信)
IntelSupport
管理者
1,923件の閲覧回数
Hi David Rosner,
Thanks for reaching out.
Currently, we do not have any ENet architecture pre-trained models available in OpenVINO. However, could you share your models ( Lua/Torch and Caffe) so that we can further assist you and test them from our end? If both models can work on our end, we will update you with the information later.
Aznie
DaveInPA
新規コントリビューター I
1,911件の閲覧回数
Sure - the model I used is available at a few public sources. I believe i got this from the original authors of the Enet published paper. Its appears to be PyTorch framework. Here is one repository that has it:
https://github.com/ishacusp/ARGO_Labs/blob/master/opencv-semantic-segmentation/enet-cityscapes/enet-model.net
Using the following code worked perfectly fine for me prior to installing OpenVino and the OpenCV bindings that come with it. It runs great on my development machine but its way too slow for RasbPi. So i bought the Neural Compute stick to run it on that platform for my application. I'd be more than happy to help get to the bottom of this if it helps.
# load our serialized model from disk
print("[INFO] loading model...")
net = cv2.dnn.readNet(args["model"])
# load the input image, resize it, and construct a blob from it,
# but keeping mind mind that the original input image dimensions
# ENet was trained on was 1024x512
image = cv2.imread(args["image"])
image = imutils.resize(image, width=args["width"])
blob = cv2.dnn.blobFromImage(image, 1 / 255.0, (1024, 512), 0,
	swapRB=True, crop=False)
DaveInPA
新規コントリビューター I
1,909件の閲覧回数
This is the error I get on my end when I run the ENet PyTorch model:
[E:] [BSL] found 0 ioexpander device
i_n=0
i_c=6
i_wh=6585
index=-1
maxval=-0.156662
outPlaneTotal=131072
input.size=1 x 16 x 128 x 256
indices.size=1 x 16 x 128 x 256
outBlob=1 x 16 x 256 x 512
Traceback (most recent call last):
  File "gp.py", line 240, in <module>
    output = net.forward()
cv2.error: opencv_ngraph_layer:l352_torchMaxUnpooling:
IntelSupport
管理者
1,899件の閲覧回数
Hi David Rosner,
Thank you for the model. We are checking on this and will update you with the information soon.
Aznie
IntelSupport
管理者
1,873件の閲覧回数
Hi David Rosner,
We have tested your model and unfortunately, the .net format model is currently not supported by OpenVINO. Meanwhile, looking at the repository that you shared, the model is similar to our semantic-segmentation-adas-0001. I would suggest you explore the model instead with our Image Segmentation Python Demo to see whether it fits with your usage.
Aznie
IntelSupport
管理者
1,824件の閲覧回数
Hi David Rosner,
This thread will no longer be monitored since we have provided the information and suggestion. If you need any additional information from Intel, please submit a new question.
Aznie
返信
