6595 Discussions
AttributeError: module 'mvnc.mvncapi' has no attribute 'EnumerateDevices'
OS Ubuntu 16.04.
I have installed the ncsdk 2 from the following source:
"git clone -b ncsdk2 https://github.com/movidius/ncsdk.git"
Install and make examples: OK
I have tested the NCS installation using the hello apps with success.
I want to use the the application "image-classifier" from ncappzoo, source:
"git clone https://github.com/ashwinvijayakumar/ncappzoo"
When I execute "make run" or #python3 image-classifier.py , I receive the following error:
When I execute the Hello apps within the ncappzoo I have some errors, the last lines below:
cpp/hello_ncs.cpp:40:43: error: ‘mvncCloseDevice’ was not declared in this scope
retCode = mvncCloseDevice(deviceHandle);
cpp/hello_ncs.cpp:42:20: error: ‘MVNC_OK’ was not declared in this scope
if (retCode != MVNC_OK)
Makefile:10: recipe for target 'hello_ncs_cpp' failed
make: *** [hello_ncs_cpp] Error 1
For your information, the Python3 path output is:
python3 -c "import sys; print('\n'.join(sys.path))"
/opt/workspace/ncappzoo/apps/hello_ncs_cpp
/opt/movidius/caffe/python
/usr/lib/python35.zip
/usr/lib/python3.5
/usr/lib/python3.5/plat-x86_64-linux-gnu
/usr/lib/python3.5/lib-dynload
/usr/local/lib/python3.5/dist-packages
/usr/lib/python3/dist-packages
Why the examples in the NCSDK run and the applications from ncappzoo do NOT work?
Please, do you have some suggestions to solve it?
Thank you
Have you switched to the ncsdk2 branch of the ncappzoo repository?
