6577 토론
Benchmark_app for Whisper model will failed on GPU
WT_Jacko
초급자
4,146 조회수
Hi Sirs,
Here is my BKC:
1. OS : ubuntu 22.04
2. Model : https://github.com/openvinotoolkit/openvino_notebooks/tree/main/notebooks/227-whisper-subtitles-generation
3. GPU : intel ARC pro 60
4. OpenVINO version : 2023.0
Description:
Use OpenVINO 2023.0 Benchmark_app to run [openvino_notesbooks 227-whister] model will failed
Error messages from GPU:
 From error messages that can know you need to provide dynamic input shape .  I have referred to the  227- notesbook, but no matter how I fill it out, I am unable to succeed.
Thanks your help
BR
Jacko
0 포인트
10 응답
Aznie_Intel
중재자
4,120 조회수
Hi Jacko,
Thanks for reaching out.
How did you run the benchmark_app with 227-whisper-subtitles-generation notebook? What command did you use? Please share your workaround and the error that you got for us to further investigate this.
Aznie
0 포인트
WT_Jacko
초급자
4,114 조회수
Hi Aznie,
My Testing Steps are as below:
1.  Use openvino_notesbooks-227 to get whisper IR model Model
=> https://github.com/openvinotoolkit/openvino_notebooks/tree/main/notebooks/227-whisper-subtitles-generation
2. The attachments are my Execution command and Error Message, please check it.
Thanks your help
BR
Jacko
0 포인트
Aznie_Intel
중재자
4,064 조회수
Hi Jacko,
Thanks for your patience.
The issue is expected since GPU only supports dynamic axis for batch size with a fixed upper limit. You may refer to this Dynamic Shapes documentation.
Aznie
0 포인트
WT_Jacko
초급자
4,023 조회수
Hi Aznie,
Thanks for your response.
First , I don't understand what is your error messages. it is not same that I attached.
please see my another attachment that is call Execution command.png.
Actually, I just wanna use benchmark_app to test whisper model  simply.  but i don't know how to run correct command include right parameters.
Thanks alot.
BR
Jacko
0 포인트
Aznie_Intel
중재자
4,007 조회수
Hi Jacko,
The error message shows that the 227-whisper-subtitles-generation notebook and model used are not supported on GPU plugin. The model can be inferred on CPU but not GPU.
There is nothing wrong with your command but I suspect that you will need to specify your input shapes of your model. Below is my benchmark_app inferred with whisper model on GPU plugin.
 Please share your model files .xml and .bin files for us to validate from our end.
Aznie
0 포인트
WT_Jacko
초급자
4,002 조회수
Hi Aznie,
Here is my model link : https://drive.google.com/file/d/1wvkdvJTAqGh0yAT7cyPxQm7-ydsXbdXl/view?usp=drive_link
by the way,  in last message i cannot see your " benchmark_app "  command.
BR
Jacko
0 포인트
Aznie_Intel
중재자
3,981 조회수
Hi Jacko,
I have requested access to your model files.
Aznie
0 포인트
WT_Jacko
초급자
3,974 조회수
Hi Aznie,
Yes, please check it.
BR
Jacko
0 포인트
Aznie_Intel
중재자
3,952 조회수
Hi Jacko,
From my validation, whisper_encoder (.onnx and .xml) are able to be run with Benchmark_app. Command used :benchmark_app -m C:\Users\Downloads\Whisper\Whisper\whisper_encoder.onnx -d GPU
However, the whisper_decoder(.onnx and .xml) both fail with data_shape error. Starting from the 2020.4 release, OpenVINO™ supports reading native ONNX models. You may also use your ONNX model without converting if nothing's wrong with it/supported.
Aznie
0 포인트
Aznie_Intel
중재자
3,787 조회수
Hi Jacko,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
0 포인트
응답
