ncs2 USB stick, windows 10, try to use ncappzoo.
How can i fix this one? ncappzoo\apps\simple_classifier_cpp_camera
18/02/2020 18.14 <DIR> build
17/02/2020 23.07 1.179 CMakeLists.txt
18/02/2020 00.58 13.997.116 googlenet-v1.bin
18/02/2020 00.58 80.636 googlenet-v1.xml
17/02/2020 23.07 3.705 Makefile
17/02/2020 23.07 2.756 README.md
17/02/2020 23.07 9.189 run.cpp
d:\"Program Files (x86) 2"\IntelSWTools\openvino\bin\setupvars.bat
d:\Program Files (x86) 2\IntelSWTools\openvino\ncappzoo\apps\simple_classifier_cpp_camera>make all
\033[1;33m\nsimple_classifier_cpp_camera: Compiling default model to IR...\033[0m
- Googlenet IR files found. No need to compile.
\033[1;33m\nsimple_classifier_cpp_camera: Making default models...\033[0m
\033[1;33m\nsimple_classifier_cpp_camera: Making dependencies...\033[0m
\033[1;33m\nsimple_classifier_cpp_camera: Downloading the required data...\033[0m
(cd ../../data/ilsvrc12; make;)
make[1]: Entering directory '/d/Program Files (x86) 2/IntelSWTools/openvino/ncappzoo/data/ilsvrc12'
\033[1;33m\nMaking all for ilsvrc data... \033[0m
make[1]: Leaving directory '/d/Program Files (x86) 2/IntelSWTools/openvino/ncappzoo/data/ilsvrc12'
\033[1;33m\nsimple_classifier_cpp_camera: Building the sample...\033[0m
Intel OpenVINO environment is already set!
(mkdir -p build; cd build; cmake ..; make)
-- Selecting Windows SDK version 10.0.18362.0 to target Windows 10.0.18363.
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
INFERENCE_ENGINE_LIB
linked by target "simple_classifier_cpp_camera" in directory D:/Program Files (x86) 2/IntelSWTools/openvino/ncappzoo/apps/simple_classifier_cpp_camera
OPENCV_CODECS
OPENCV_CORE
OPENCV_HIGHGUI
OPENCV_IMGPROC
OPENCV_VIDEOIO
-- Configuring incomplete, errors occurred!
See also "D:/Program Files (x86) 2/IntelSWTools/openvino/ncappzoo/apps/simple_classifier_cpp_camera/build/CMakeFiles/CMakeOutput.log".
make[1]: Entering directory '/d/Program Files (x86) 2/IntelSWTools/openvino/ncappzoo/apps/simple_classifier_cpp_camera/build'
make[1]: *** No targets specified and no makefile found. Stop.
make[1]: Leaving directory '/d/Program Files (x86) 2/IntelSWTools/openvino/ncappzoo/apps/simple_classifier_cpp_camera/build'
make: *** [Makefile:60: compile_cpp] Error 2
Hi TNguy219,
Thank you for reaching out.
The Neural Compute Application Zoo (ncappzoo) repository was tested and known to work on the Ubuntu 18.04 OS, and it will likely work on other Linux based operating systems. Windows has not been tested yet, you can try it but, it may or may not work.
Javier A.
A Contingent Worker at Intel
![](/skins/images/7FDC486457F5FB4D87FED5D8C92AC987/responsive_peak/images/icon_anonymous_message.png)
