6619 Discussions
CNNNetwork ReadNetwork(const std::string& model, const) is throwing error as unknown file: Failure
Subtle
I am using  CNNNetwork ReadNetwork(const std::string& model, const Blob::CPtr& weights) function for loading models from memory.
My code looks like:
//vector<uint8_t> model (.xml)
//vector<uint8_t>weights (.bin)
//for creating TensorDesc
InferenceEngine::TensorDesc tensor(InferenceEngine::Precision::U8,{weights.size()}, InferenceEngine::Layout::ANY);
//For creating Blob
InferenceEngine::TBlob<uint8_t>::Ptr wei_blob = InferenceEngine::make_shared_blob<uint8_t>(tensor,&weights[0],vec_s);
here vec_s is of type size_t
//calling readnetwork
//std::string strModel(model.begin(),model.end());
InferenceEngine::Core ie;
InferenceEngine::CNNNetwork network =  ie.ReadNetwork(strModel,wei_blob);
My code is getting compiled but when i am running this, it is throwing error :
C++ exception with description "Failed to construct OpenVINOImageInference" thrown in the test body.
I am not getting what is the issue.
How can i resolve this.
Thanks a lot
Zulkifli_Intel
Hi Subtle,
Thank you for sharing the screenshot of the error. Unfortunately, support is hard to come by with your limited information. Is it possible to share your code and steps to reproduce the issue via email
Sincerely,
Zulkifli
Zulkifli_Intel
Hi Subtle,
Thank you for getting in touch.
Which OpenVINO version did you use? We would really appreciate it if you could share the complete file (including the model) for us to replicate and investigate further.
Sincerely,
Zulkifli
Subtle
Hi Zulkifli_intel,
Thanks for replying.
I am using OpenVINO 2021.4 version and OS is Ubuntu 20.04 LTS. I am sorry, i can't share the complete file. I will try to cover needed information in my code snippet here. For my use case i am not going for any particular model. For current scenario i am using face-detection-retail-0004.xml , age-gender-recognition-retail-0013.xml, emotions-recognition-retail-0003.xml with precision FP32 .
My code looks like(updated):
I have .bin and .xml file stored on disk. I am storing these .bin and .xml to vectors of type uint32_t.
// xmlFile is xmlFile path
//binFile is binFile path
string xmlFile;
string binFile;
vector<uint32_t> model (.xml)
vector<uint32_t>weights (.bin)
//storing xmlFile in vector<uint32_t> model
//stroing binFile in vector<uint32_t> weights
InferenceEngine::TensorDesc tensor(InferenceEngine::Precision::U32,{weights.size()}, InferenceEngine::Layout::ANY);
//For creating Blob
InferenceEngine::TBlob<uint32_t>::Ptr wei_blob = InferenceEngine::make_shared_blob<uint32_t>(tensor,&weights[0],vec_s);
Thank you
Zulkifli_Intel
Hi Subtle,
Sorry for the delay in replying. The "Failed to construct OpenVINOImageInference" error is incomplete. Is there an error message before and after this line? This information may help point to the actual problem you are having.
Sincerely,
Zulkifli
Subtle
Hi Zulkifli_intel,
There is no error message before and after this.
I have attached ss for your reference.
Thank you
Zulkifli_Intel
Hi Subtle,
Sincerely,
Zulkifli
Subtle
Hi Zulkifli_intel,
Yeah, Sure. I will share artefacts via mail.
Thanks a lot
Zulkifli_Intel
Hi Subtle,
You can send it to my email: [email protected]
Sincerely,
Zulkifli
Zulkifli_Intel
Hi Subtle,
By referring to Executable Network, the recommended flow is to read IR content and follow by reading blob content with formatting and allocation before using ReadNetwork to load both.
 // read XML content
std::string xmlString;
std::uint64_t dataSize = 0;
model.read(reinterpret_cast<char\*>(&dataSize), sizeof(dataSize));
xmlString.resize(dataSize);
model.read(const_cast<char\*>(xmlString.c_str()), dataSize);
// read blob content
InferenceEngine::Blob::Ptr dataBlob;
if (0 != dataSize) {
dataBlob = InferenceEngine::make_shared_blob<std::uint8_t>(
InferenceEngine::TensorDesc(InferenceEngine::Precision::U8,
{static_cast<std::size_t>(dataSize)},
InferenceEngine::Layout::C));
dataBlob->allocate();
model.read(dataBlob->buffer(), dataSize);
auto cnnnetwork = _plugin->GetCore()->ReadNetwork(xmlString, std::move(dataBlob));
In the code, after the blob is created - it was directly fed into ReadNetwork which 'might' potentially caused the error.
// create blob
InferenceEngine::TensorDesc O_tensor(InferenceEngine::Precision::U32,{weights.size()},InferenceEngine::Layout::ANY);
std::cout<<"created tensordesc"<<std::endl;
InferenceEngine::TBlob<uint32_t>::Ptr wei_blob = InferenceEngine::make_shared_blob<uint32_t>(O_tensor,&weights[0]);
std::cout<<"Created blob"<<std::endl;
//Read Network
InferenceEngine::CNNNetwork network = IeCoreSingleton::Instance().ReadNetwork(strModel, wei_blob);
Sincerely,
Zulkifli
Hari_B_Intel
Hi Subtle,
Thank you for your patience, after investigating, we found that the model and weight vector are defined as <uint32_t>, and the InferenceEngine::Precision is set to U32.
So in your code provided, the code was successfully executed after changing the vectors to <unit8_t>, and InferenceEngine::Precision to U8. You can give it a try and see if it works on your program.
std::vector<uint8_t>n_model;
std::vector<uint8_t>weights;
InferenceEngine::TensorDesc O_tensor(InferenceEngine::Precision::U8 {weights.size()},InferenceEngine::Layout::ANY);
InferenceEngine::TBlob<uint8_t>::Ptr wei_blob = InferenceEngine::make_shared_blob<uint8_t>(O_tensor,&weights[0]);
Hope this helps.
Thank you
Zulkifli_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Zulkifli
