6574 Discussions
CPU Processing speed variations on two intel processors
terry01000
I have an application that run good on intel processor  m3-8100Y, but slower on Celeron N5105 @ 2.00GHz while N5105 is expected to be 25% faster. My quick question are:
1. Is there architecture difference between the two processors that require the openvino to compile individually ?
2. Other typical cause of CPU processor not performing on it's max power?
Environment:
Openvino 2022.1
Windows 10
Object Detection: ssdLite-mobile
IR on CPU
Thanks in advance
Hairul_Intel
Hi terry01000,
Both of the processors you've mentioned are not officially supported nor have they been validated by OpenVINO™.
However, I've checked publicly available benchmark (This is an external link and is not maintained by Intel) and discovered that for single core, Intel® Core™ m3-8100Y processor performs better than Intel® Celeron® Processor N5105 in Cinebench R20 test.
Regarding architecture differences, Intel's architecture spans an array of features, performance, and power levels. The Intel® Celeron® N5105 is primarily intended for inexpensive desktops while the Intel® Core™ m3-8100Y is for tablets and passively cooled notebooks.
For your second question, the typical causes for CPU not performing at full speed or capacity might be due to issues with the CPU driver, power management or even system related issues.
From OpenVINO™ perspective, I've validated the ssdlite_mobilenet_v2 model by running Object Detection Python Demo with the model on Intel® Core™ i7-8665U CPU. Here is the performance result of the demo:
Hairul
Hairul_Intel
Hi terry01000,
Hairul
terry01000
Hi Hairul,
Thank you very much for the quick respond and taking time to investigate the questions. It's very helpful.
I got the similar processing speed as your test for m3-8100Y. But not Intel® Celeron® N5105 as expected based on your responds.
Is the officially supported processor listed somewhere in a  documents?
Terry
Hairul_Intel
Hi Terry,
Glad to be of help.
You can find more information regarding officially supported hardware for OpenVINO™ from the Supported Devices page.
Additionally, here is the Intel® Distribution of OpenVINO™ toolkit Benchmark Results for supported and validated hardware (CPU, GPU or VPU).
Hairul
Hairul_Intel
Hi Terry,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Hairul
